Guys
Been busy with my build and I am doing some painting, then the dreaded Zimmerit! I am wondering what varnish/lacquer do you use to protect the paint? I have tried Autotek matt lacquer which darkens the overall finish and then tried Hycote lacquer which is slightly lighter when applied but still darkish. The Base colour I am using is Tamiya TS 3 dark yellow.
Look forward to the response guys?
Keep Safe Allan
Varnish/Laguer
- Has liked: 792 times
Re: Varnish/Laguer
Hi Allen
To be honest I did not use any varnish or lacquer to protect the paint.
- Has liked: 1038 times
Re: Varnish/Laguer
Allan
You don’t really need a varnish unless you want to create a protective layer over the base coat in order to apply weathering. I use a water based acrylic varnish in rattle cans. I would have recommended the one from Games Workshop which used to be called Purity Seal or now Munitorum Varnish (who thinks up these weird names?) neither seem to be available t the moment.
I see that Vallejo produce a similar varnish and that’s probably the best bet. One tip, don’t apply too thickly or it may silver or frost over. A couple of very light mists is all you need.
- Been liked: 10 times
- Has liked: 7 times
- Been liked: 46 times
Re: Varnish/Laguer
This stuff works ok for me. Available in all good art shops.
- F81073E4-5D72-4796-AD70-1E2F25DEC6B6.jpeg (34.54 KiB) Viewed 1403 times
