New option pack, heads up
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
For those that are about to install the new option packs a quick heads up of a small issue I have found.
After installing the motion and audio modules to a Stug that I am building I carried out a function test and everything was working as advertised. I then installed the recoil module and powered the up again and this time nothing worked.
After a bit of investigation I noted that the receiver was not powered and so nothing worked.
The fix is very simple and all that is required is the red (power) wire removing from the link cable between the audio module and recoil module, with the cable removed everything now works.
The photo below shows the link cable and the removed power wire, just need to insulate and tie the wire away.
michael hilton
Has liked: 1565 times
Been liked: 835 times
Re: New option pack, heads up
Post by michael hilton »
Hello Steve, I had a similar issue when setting up my new modules on the M3 Grant. Adrian pointed this 'fix' out to myself in a PM. I thought this was just my problem. Thanks for posting. Mick
Steve Norris
Has liked: 8 times
Hi Michael
Simple fix when you know what the issue is, but it may make some people think they have blown something if you do not realise what the problem is.
Phil Young
Has liked: 40 times
Been liked: 59 times
Post by Phil Young »
Hi Steve, thanks for the heads up. Have you made Armortek aware of this fault?
Phil.
Steve Norris
Has liked: 8 times
I haven’t yet but Kian and Monique do read the forum so I guess they would now be aware.
