2003 Tiger 1 Mid landed in Belgium
Tom Opsommer
Been liked: 13 times
Post by Tom Opsommer »
Hello all,
So I managed to capture a 2003 tiger 1 from Simon Manning. Before I start this interesting build. I will be looking for some good reference material.
If anyone has any good suggestions I love to hear about them. As I'm not sure what exact tiger I will be making.
Has liked: 790 times
Re: 2003 Tiger 1 Mid landed in Belgium
Hi Tom. Will surely follow your build if you intend to show it. Just finished my Tiger 1.
Tom Opsommer
Hi Vince
I will try to keep a log of the build. It won't be a quick one as Im abroad allot for work
mark lawson
Has liked: 2519 times
Been liked: 444 times
Post by mark lawson »
Best books would be Tigers in Combat Vol 1 to 3 the English versions are long out of print but in German its readily available then you have the series of books from Thomas L Jentz, D.W to Tiger I, Tigers at the front and Tiger I and II combat tactics, steer clear of anything from Waldemar Trojca his line drawings are known to be completely wrong and his colour plates are a figment of imagination for on line reference you could do no better than http://tiger1.info/ I hope this helps a little
RAG Militärmodellbau
IG Militärmodellbau
Tom Opsommer
Thank you helps allot I ordered the 3 volumes.
Christoffer Ahlfors
Has liked: 745 times
Been liked: 359 times
Post by Christoffer Ahlfors »
mark lawson wrote:
Fri Jan 31, 2020 12:57 pm
Learned something there - thank you! :)
Tom Opsommer
So after weeks of being abroad and removing surface rust. I finally started a first test fit of the hull.
Now waiting for an extra spray can of etch primer to do the last pieces for the final assembly.
David Brady
Has liked: 211 times
Been liked: 838 times
Post by David Brady »
Looks good to me!
Tom Opsommer
So I am not so good at remembering to take pictures and sharing a build.
Luckily I remembered to take some pictures today.
So the hull is now one piece.
I did a ton of painting and my first zimmerite.
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
Good work :D
cheers
Steen
