What a palaver!
I've got pigs teats for fingers so fitting ED0506 into EDO0501 (needed a little needle filing so that 0501 slipped over the pins), then fitting a M2 x 8 cap screw and an M2 nut had me trying to hold a three fingered job with only two
And then I found I was fitting a Track Pad EN0502 upside down, I hadn't noticed that the holes are off set to one side !!! Next Time I'll look at things under a 100 watt lamp with a magnifying Glass.
This afternoon while waiting for paint to dry I tried assembling a Road Wheel. A word of caution here chaps.
I put the two bushes, ED0108 in the Hub EN0109 and tried to fit the axle, ED0107. Didn't go in. Ah, I thought burrs. Did a bit of deburring with a file, no joy.
Micrometered the shaft, a tad over 8 mm, so we might have to put an expanding reamer through the bushes to make sure that
A) the axle will go through without binding and
B) that the bushes are lined up,
I find with experience that this is not unusual, although Bar stock is nimolly 8 mm (or whatever) it is often a few thousandth out while the bushes may be made to size.
This will probably NOT surprise many of you.
paint should be dry now so back to that
PS, ONLY 753 rivets, the Mk.IV has nearly double that..............Have lots of Fun Chaps, I'm going to.........every time I hammer a rivet i'm thinking of someone.......
