Hi everyone, currently I'm getting the radio mounted / calibrated to the tiger 131 w/ 2016 motion pack. When I hook everything up to the radio the two front sprockets run at full throttle uncontrollably. When I connect a simple servo to these same channels they work fine.
I remember encountering something similar to this on the elevation on my last build and to fix this I had to throw a dip switch. Do I need to do something similar with these channels too? I just wanted to ask on here before I go and tamper with anything
For the radio my specs are listed below,
Futaba 14SG 2.4ghz
https://www.futabarc.com/systems/futk9410-14sg/
any help would be of great use. thanks John
Tiger 131 drive control question
- Been liked: 48 times
- Has liked: 1495 times
- Been liked: 1699 times
Re: Tiger 131 drive control question
What receiver do you have and do you know which mode is being used (FASST or S-FHSS) ?
on the RX it has FASST on the label. As for which setting is on the radio... I'm not sure I want to say that it is at the stock setting as I just opened the packaging.
Yes that looks to be the exact problem. I went ahead and sent the radio back in place for a different unit. The unit I had was a bit overkill for what was needed. Thanks again.
