First Armotek Tank (and second r/c model ever!).
Chris Hoole
Post by Chris Hoole »
Just wanted to say a quick hello having obtained an Armortek Tiger 1 at long last (2012 edition, hull number 10). It has taken a while but what a gorgeous thing it is too - very thrilled with it! Up until now the first r/c model I had was a model works Tiger purchased just 6 months ago, so I am still trying to grasp some of the basics.
I have given the tank a preliminary look over (it has motion, smoke and sound options) and I have a couple of initial questions: Is there just the one build manual consisting of 79 pages? The track adjusters at the rear of the tank are hard up against the rear of the hull - I presume this is not normal? Is this solved by removing a piece of track (currently the tracks are made up of 92 pieces)? Is the sound module for engine sounds only or will it do machine guns, main gun, and other sounds? The smoker seems to be smoking everywhere not just out of the exhausts, whilst this looks quite dramatic, I presume they are not supposed to!? The gun elevation is not one smooth motion but in stages (with pauses), is this correct? I have a couple of broken hatch hinges - are spare parts readily avaialble?
Many thanks for any advice given.
Cheers Chris.
Has liked: 1475 times
Been liked: 1674 times
Re: First Armotek Tank (and second r/c model ever!).
Welcome Chris.
There should be a contruction manual for the Tiger, plus separate instructions for the Motion Pack including the electrics, the sound, recoil and smoke.
Not run a TIger but it doesn't sound like it. I believe the tracks should touch down on the second or third road wheel when properly tensioned.
Assuming it came with a Benedini based sound system, it should do all the above, plus various voices and machinery whines.
No. Check all the plumbing is air-tight, and that the teflon washer which holds the element isn't burnt or loose.
Sounds like the elevation screw is bent, or not sitting on the elevation motor gearbox shaft correctly.
Yes, Monique will gladly supply spares, if you can identify the part numbers from the manual.
Chris Hoole
Hi Adrian,
and thank you for your response.
Here is a photo of the Manuals I have, but they are very sparse. The motion pack manuals are just several pages and the main build manual is thicker but much of it resembles a parts catalogue - should there be one for each assembly pack (sprockets, suspension, turret etc)?
I will move the question about the track tensioners to the Tiger 1 page.
Thanks for the heads up about the sound. With your answer I have found more on the topic and can see that the Armortek module can be opened to give access to the Bendini Card (something to work on later!).
You were right about the gun elevation screw bieng bent (good call!).
The smoker I will remove and take a closer look at.
Thank again - really appreciate the help.
Ps Did we meet at Cobbaton Tank Museum a couple of months ago (with Denny Patterson)?
There's just one chapter per pack, rather than a complete manual.
Yes, we did meet at Cobbaton :-)
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Post by Dennis Jones »
Hi Chris,
Having built a late Tiger some while ago. Yes the barrel does elevate in stages. The track adjusters sit in brass bushes up against the hull. The sound module should do all the sounds. Yes you get all the manuals.
dennis.
Chris Hoole
Thank you both for the additional information, very helpful. I have moved the issue of the tracks (which seem very short as compared to others!) to the Tiger 1 section. Glad to have met you Adrian and put a face to the name!
