Use an apple press,it's easier. ...joking aside me ol mate ive never put one together, but some photos of the offending part for the aficionados will help no end, as it always does!
Hi Leon,
I acquired a pak43/41 last year that had been built by someone else. When I had a look at the suspension, which was faulty, I found there is a screw placed at the centre of the axle underneath the gun. This screw had stripped the thread so had allowed the axle to rotate and the suspension collapsed. I re tapped the hole to a slightly bigger size and that cured the problem. Hope that helps.
All the best
Kevin.
Freedom is a privilege that must always be fought for.
