Mosfet 2n06L07 help please
Has liked: 2279 times
Been liked: 7191 times
I have a 2010 Armortek speed control module that requires a pair of mosfet/power transistors with the code 2n06L07 (AG051) the only ones I can find (Ebay) with the exact code are in Italy with postage of nearly £12, can anyone help with an equivalent item, many thanks Phil.
Has liked: 1470 times
Been liked: 1643 times
Re: Mosfet 2n06L07 help please
They're available from Farnell - Part Code 2725872
Thanks mate, we can always rely on you for the technical info :D .
I do have just one another technical question regarding a 2010 amp module I have acquired; one of the track function rx inputs was connected with the signal wire and the negative around the wrong way, there is no acceleration sound function on that channel although the motor function is unaffected, (the other channel is fine) what do you think was damaged, the sound card or something else? I really do appreciate your superior knowledge in these matters Adrian! cheers Phil
No worries.
On the Amp Module, the inputs go straight to the Benedini board, so I would guess that is the part which has blown.
Thanks so much buddy much appreciated, I shall try to find an older large Panther TB sound board many thanks Phil. :D
