Hi there
I do not use the switch unit original designed for the Blank Firer Unit.
a thought - could I connect the + & - from my Bosch front light and Rear light to the switch unit and then control the light on/off over a spare channel on my radio
cheers
Steen
Switch Unit to control Front and Rear Light
- Steen Vøler
- Has liked: 62 times
- Been liked: 500 times
- Has liked: 1478 times
- Been liked: 1682 times
Re: Switch Unit to control Front and Rear Light
Hi Steen.
If you have the switch, then you may as well make use of it
You only need to connect the +ve through the switch, not both.
- Been liked: 177 times
Hi Steen I use one of these on all my models to control the convoy lights.
http://www.robotmarketplace.com/product ... SW1_lg.jpg
Works great
Works great
- Steen Vøler
- Has liked: 10 times
- Been liked: 224 times
Hi Steen,
If you connect the front and rear lghts in series providing they are both 12 volts you can run the lights from the Armortek aux module direct and no need for a switch unit come back to me if you need further details.
