Switch Unit to control Front and Rear Light
Steen Vøler
Has liked: 62 times
Been liked: 499 times
Post by Steen Vøler »
Hi there
I do not use the switch unit original designed for the Blank Firer Unit.
a thought - could I connect the + & - from my Bosch front light and Rear light to the switch unit and then control the light on/off over a spare channel on my radio
cheers
Steen
cheers
Steen
Has liked: 1421 times
Been liked: 1603 times
Re: Switch Unit to control Front and Rear Light
Hi Steen.
If you have the switch, then you may as well make use of it :D
You only need to connect the +ve through the switch, not both.
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
Hi Steen I use one of these on all my models to control the convoy lights.
http://www.robotmarketplace.com/product ... SW1_lg.jpg
Works great
Steen Vøler
Has liked: 62 times
Thanks Adrian & Tim :-)
cheers
Steen
cheers
Steen
Dennis Jones
Has liked: 10 times
Been liked: 223 times
Post by Dennis Jones »
Hi Steen,
If you connect the front and rear lghts in series providing they are both 12 volts you can run the lights from the Armortek aux module direct and no need for a switch unit come back to me if you need further details.
Dennis.
