This King Tiger is No30 of the original batch and will be completed with a few mods Such as adjustable torsion bar suspension, high efficency motion pack recoil and detailed engine bay.
This shot shows the partially complete turret. Those that are familiar with the King Tiger may notice that i have repositioned the track hangars, The reson for the track hangars being moved is that as supplied they are simetrical left and right but in reality they were not (you could hang the same section of 2 part track on either side).
This shot shows the turret roof removable sections removed. I thought this would be neccesary for access to the elevation and recoil mechanism.
The turret front has had the gunners sight apperture detailed and the MG port position moved with the correct shape cut out added, i have also added the MG armoured shield.
A closer view of the MG and cut out. The MG is attached to the main gun elevation arm and now moves in sinc with the main gun.
The gun mantlet has been reshaped so that it is wider nothe left and deeper at the top, A bit of texture and gas card holder have also been added.
A view of the new gun recoil sleeve and modified mount and elevation.
The turret rear hatch has been detailed, At the time Steve Winstones example was not available so i did my own.
The rear hatch closed and the lock bars in the locked position.
Thats all for now.
