Steves King Tiger
Steve Norris
Has liked: 8 times
Been liked: 701 times
Steves King Tiger
Post by Steve Norris »
I have been building my King Tiger for about 3 months now and have decided its about time i posted a few photos.
This King Tiger is No30 of the original batch and will be completed with a few mods Such as adjustable torsion bar suspension, high efficency motion pack recoil and detailed engine bay.
This shot shows the partially complete turret. Those that are familiar with the King Tiger may notice that i have repositioned the track hangars, The reson for the track hangars being moved is that as supplied they are simetrical left and right but in reality they were not (you could hang the same section of 2 part track on either side).
This shot shows the turret roof removable sections removed. I thought this would be neccesary for access to the elevation and recoil mechanism.
The turret front has had the gunners sight apperture detailed and the MG port position moved with the correct shape cut out added, i have also added the MG armoured shield.
A closer view of the MG and cut out. The MG is attached to the main gun elevation arm and now moves in sinc with the main gun.
The gun mantlet has been reshaped so that it is wider nothe left and deeper at the top, A bit of texture and gas card holder have also been added.
A view of the new gun recoil sleeve and modified mount and elevation.
The turret rear hatch has been detailed, At the time Steve Winstones example was not available so i did my own.
The rear hatch closed and the lock bars in the locked position.
Thats all for now.
phil fitzpatrick
Been liked: 223 times
Re: Steves King Tiger
Post by phil fitzpatrick »
Hi Steve
Nice photo's,I like yor Rear Hatch details,nice work.
Have you lost the first 3 photographs that look as though they may have been
deleated,or can you put them back on again?
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
Hi Steve
Oh man! Another masterpiece is on the way. Incredible looking detail on the turret.
Happy New year
so much extra detail has been discovered, very nice as always regards simon manning.
Steve Norris
Has liked: 8 times
Thanks guys.
Not sure what happened to the first 3 shots but hopefully they should be there now.
Chang
Has liked: 16546 times
Been liked: 487 times
Post by Chang »
Hi Steve,
Your turret looks great already.
The modifications on co-axial MG synchro with main gun, and main gun recoil sleeve mechanism are real inspirations! I have been waiting long enough for them shown up someday by skillful builder. The waiting is over!
If you consider to release them as aftermarket parts later on, please count me in.
Also can't wait to see the adjustable torsion bar suspension and high efficency motion pack installed.
Lerh Chang :D
Steve Norris
Has liked: 8 times
Lower hull sides have now been completed and are almost ready for the final assembly of the hull
This first shot shows both lower hull sides, Details added to the bump stops, Repositioned suspension damper mounting pins, Torsion bar end fixtures added.
You may also notice the 4 studs where the lower part of the gear case will sit,The reason for these will become more obvious after the hull is assembled and the armoured shields are added for the gear cases.
One of the detailed bump stops, I copied John Grimas idea (Hope you dont mind) and made a plastic master of the top side detail and cast 4 tops in white metal.Cap head screws have also been replaced by bolts.
Another view of the bump stop and some of the torsion bar end fixture detail, I know its not exactly right but it is not realy going to be that visable once the suspension arms and wheels are fitted,
I still have to prime the remaining hull parts and then assembly can begin.
Roy Pickavance
Post by Roy Pickavance »
Hi Steve
She is looking really really good.
Your builds just get better and better.
Best regards. Roy
It could be worse, It could be Tuesday.
Steve Norris
Has liked: 8 times
Further work carried out on the hull.
The hull has now been assembled with all access panels added, Drivers escape hatch added and reinforcing plates added.
The final drive armour has been corrected, increasing their length by adding white metal castings i made using the supplied armour as templates.
regards
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hi Steve.
Very neat and clean as always mate another great model from you on the cards.
Cheers Paul :wink:
01524 720977
Per Sonnervik
Been liked: 2 times
Post by Per Sonnervik »
Hi Steve,
Nice work and good to see somebody detailing the bottom plates. Perhaps not 100 % correct and hard to check ones the tank is on it´s tracks but still good work.
Perhaps to late to change but one detail that is wrong is this one (see circle);
This detail should only be on right side (not as here on the left as well). I´ve tried to work out the purpose of this detail but so far I haven´t got a clue - remains a mystery.
Keep up the good work.
/Per
Steve Norris
Has liked: 8 times
Hi Per.
Thanks for the reply, It should not be to much of a problem to remove the stud on the left.
The added detail parts are not 100% accurate as you said but close enough to be convincing when the tank is on its tracks, (you never know I may end up rolling it over !).
Paul Wills
Has liked: 646 times
Been liked: 143 times
Post by Paul Wills »
Hi Steve,
I wouldn't recommend it, but if you do, make sure you have a camera as it will make a good diorama! :shock: :wink:
Paul.
Tim Bowman
Please don't turn it over.
keep up the great work
Steve Norris
Has liked: 8 times
Nice one Tim,
Hopefully I can keep it on its tracks !!
