Ragnar`s 2010 Tiger build
- Been liked: 13 times
Hi all
Some more pic of my Tiger build, any comments welcome Regards Ragnar
THANKS FOR THE TIGER`S
2010 mid-Tiger Nr.005
- Been liked: 223 times
Re: Ragnar`s 2010 Tiger build
Well done Ragnar,
Your Tiger is coming together nicely,looking good,
Keep posting the pictures as you progress.
- Has liked: 704 times
- Been liked: 306 times
Awesome detail, Ragnar!
This is a top notch build - you have done all the things I am only dreaming of!
/Chris
/Chris
Hi All
Some pic. of my feifel system mod. It is Mike`s system that I have done some work on.
The rework has been done with styren strips and the filler I used are plastic padding PP100. If it gets right it is intended to be a single chamber system. Ragnar
Hi Ragnar
You have done some more nice work there,with the adaption
of your Feifel.
Nice pictures
of your Feifel.
Nice pictures
More Feifel pic.
Almost completed, some small parts need to be added and a final primer and paint. It is still Mike`s feifel parts,just modified. It was an close fit between the jack and the schrapnel bracket. The long air hoses,nedded the removal of two rings. The lower and upper brackets had to be made of brass sheet, due to the whitemetal would brake apart as I had to bend them.
Ragnar
Ragnar
- Been liked: 177 times
Hi Ragnar
Beautiful work! That will be one very nice looking Tiger.
- Has liked: 1365 times
- Been liked: 1564 times
This Tiger's going to be a shop stopper when you've finished with
Hi Ragnar
Lovely pictures of your Tiger details.
Great Stuff
Great Stuff
Absolutely fantastic detail!
One little thing among others are the engine hatch closing/tightening locknuts. The eight or so little round things with a square recess in them around the perimeter of the hatch. How on earth did you make them? And the other ones with a recessed square protrusion? If you would like to share the technique, I would be so grateful.
Thanks,
/Chris
Thanks,
/Chris
Hi Chris
It is very simple, take the screw and cut of head. The screw are used for fixing wooden trims around windows and floors. The problem is that some places have them with torx head, and others with Robertsen (known as R1-R3.
The hex head is 2,5m/m , started with 4m/m drillbit and flatend with the milling tool
I hope this is of any help, and i have taken a photo of a little set up
Ragnar
Ragnar
- Been liked: 1633 times
this is a nice build going on here ragnar, keep the posts coming. regards simon manning.
Brilliant idea with the wood screw!
Thanks for the instructive photo.
/Chris
/Chris
Hi All
Some more pic. of my rear plate and rear deck An comments on this,good or bad
Ragnar
Ragnar
- Been liked: 429 times
Got it Ragnar . Very nice workmanship you are doing a wonderful build so far well done.. Dale
