Since the introduction of the new web site i have been unable to post any photos, I keep getting the message "Your images may only be up to 750 pixels wide". There is obviously a way round this but i cannot find it, can anyone tell me how it is done.
I use Photobucket as my hosting site if that makes any difference.
New web site
- Has liked: 8 times
- Been liked: 701 times
- Has liked: 6 times
- Been liked: 801 times
Re: New web site
I use photobucket also. When you upload there is an option to customise where you can set it to resize all photos to a particular set size. There is none for 750, so unless you go for a smaller size you need to edit each image and resize. Click on edit, resize and enter 750 in the box for horizontal size. The vertical should change itself to suit.
- Has liked: 1566 times
- Been liked: 836 times
Re: New web site
Hello everyone, here is my fourpenny worth.....I have difficulty reading the posts....black letters on the grey background. White script on grey suits me fine.
I resize my photographs ( taken with my digital camera then loaded directly into 'pictures' on my laptop) to 800x600. I stopped using Photobucket, takes to long to load and transfer....Mick.
- Has liked: 10 times
- Been liked: 224 times
Re: New web site
Hi Steve,
In photobucket click on the photo position the cursor near the top of the photo list of options appear, select resize and choose 640 x 480 then select replace original and that should work.
- Been liked: 177 times
Re: New web site
Hi everyone
You can also just type 750 in the "width" box and it will keep the proportions. Then as John said, either save as copy or replace original.
best regards
best regards
- Has liked: 1479 times
- Been liked: 1683 times
Re: New web site
We seem to have lost the piccie for the Taper Lock Bush Installation from this post in the Official Advice forum:
http://www.armortek.co.uk/Forum3b/viewt ... f=3&t=2250
- Been liked: 3689 times
Re: New web site
Hi Adrian
I have now put the instructions in the post. You need to click on it to increase the size to read. It works fine on the full screen although if viewing on a lap top it may not be perfect. If anyone needs a copy I have a 'hi res' that I can email on request. These instructions are also in all the relevant kit manuals.
Gill
Gill
Re: New web site
Thanks Gill
