Hull Mounted MG
ChrisWilliams
Hull Mounted MG
Post by ChrisWilliams »
Hi all,
Just picking your brains again.........
What MG type was mounted in the hull (as in next to the drivers poistion)?
Was it just a standard MG or one made for that particular job.
The reason I ask is that I have a couple of DID MGs and was considering fitting one in the Panzer IV
leesellars
Been liked: 15 times
Post by leesellars »
Hello Chris
The Hull Mg34 had a special Barrel that was armored for obvious reasons.The barrel was solid with two slits in it.It didnt have holes in it as with the Infantry version. To see one look at the latest Bobby Woll Figure as he has one aswell as a Gurt sack.
lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
ChrisWilliams
MG
Hi Lee,
Thanks for you replie, so were all hull mounted MGs the armoured type or were these brought in in the later years of the war and was it only the MG
34s that were used for this particular role?
Kent Wiik
Post by Kent Wiik »
Hi Chris,
The MG34 modified or MG34T (tanker) came 1942 so before that date they used the standard MG34.
Here is an interesting link:
http://www.lonesentry.com/articles/ttt/ ... -mg42.html
