Barrel Recoil
davebane
Been liked: 6 times
Barrel Recoil
Post by davebane »
Looking at buying a built Tiger to fight my T-34, and wondering if there is a barrel recoil and firing device from Armortek for this? The current tank has a blank firer, and from what I've read, I think I'd rather avoid that? I don't see one listed on the website...
Dave Bane
Steve Stuart
Has liked: 264 times
Been liked: 195 times
Re: Barrel Recoil
Post by Steve Stuart »
Dave
Keep an eye on Adrian Harris and his work on a recoil mechanism, I hope that he will eventually work out something that can be used on the Tiger. At the open day he demonstrated something that was dead impressive.
All the best
Has liked: 1490 times
Been liked: 1697 times
Re: Barrel Recoil
:oops: :oops: :oops: Thanks for the big up Steve :lol:
I have done some work on converting my recoil system to work with a 2003 Mid Tiger. I think I can manage the full 93mm recoil distance but I don't know yet if the servo I have selected is capable of handling the mass of a Tiger barrel.
My other concern is that there is very little in the Tiger gun design which can act as the linear bearing. I have found some PTFE adhesive tape which may help keep the main part of the barrel aligned and free running.
What I don't know yet is whether adding recoil will introduce an unacceptable amount of barrel bounce when the Tiger is on the prowl. :?
I guess I need to get my hull rebuilt to test it all out :roll: :roll:
Leon Hosking
Been liked: 2 times
Re: Barrel Recoil
Post by Leon Hosking »
At the risk of sounding smug, methinks Armortek are missing a trick here :wink:
My soon to be collected Mark-1-Tanks 1/8 Tiger 1 (Late Model) has a pyro gun with full barrel recoil :mrgreen:
The barrel has a GRP outer sleeve with a steel inner liner - if people could get over NGS (No Grp Syndrome), then there`s your cake get munching :lol:
As they say, go figure :arrow:
John Wiggins
Has liked: 257 times
Been liked: 147 times
Re: Barrel Recoil
Post by John Wiggins »
Hi thought you might like to see this.....
John
Leon Hosking
Been liked: 2 times
Re: Barrel Recoil
Very nice :mrgreen:
Looks just like the LED system on my Tamiya Panther :wink:
You seem to have the timing pretty bang (excuse the pun :!: ) on as well
John Wiggins
Re: Barrel Recoil
:oops: :oops: Forgot to say, Adrian was demoing his recoil system, at the Armortek open day.
John
Robin Ellis
Been liked: 8 times
Re: Barrel Recoil
Post by Robin Ellis »
This is another view of my recoil system, Please note the 'white' PTFE bearing allowing a smooth and rigid guide for movement of the barrel. Also note the 'black' plastic bush which acts as a cushioning stop. I recommend the large FUTABA 3306 SERVO , as this has 24kg of torque, essential in moving a large heavy object. You must also power this servo using a 6 VOLT NICAD, 4.8 volt is not powerful enough.
Robin Ellis
Been liked: 8 times
Re: Barrel Recoil
If you cannot get enough recoil movement with an existing Futaba servo arm, here is one that I have found which gives a much longer throw.
http://www.hobbyking.com/hobbyking/stor ... ba%5F.html
Re: Barrel Recoil
Hi Robin
Is there a video of your recoil in action that I missed? Would love to see it. :) Sorry if I simply missed it.
Robin Ellis
Been liked: 8 times
Re: Barrel Recoil
Hi Tim, no video at the moment, but will take one hopefully next week when I have fitted the new longer servo arm. By the way my son lives in Bel Air, is that far from you?
Re: Barrel Recoil
Hi Robin
Thanks. Look forward to the video. :) Bell Air is in Los Angeles which is the Southern part of our state. About a 6 hour drive for me. I think David DaCosta lives there though (or somewhere close).
All the best
Robin Ellis
Been liked: 8 times
Re: Barrel Recoil
Hi Tim, here is the promised video. The basic system is pretty crude, but it has worked successfully now for six years. However I would like to make a longer servo output arm in order to make the leverage a little straighter. For the 'slow' barrel return, I am using the TURNIGY servo speed reducer as previously mentioned.
Apologies for the jerky camera, but I was having to operate the transmitter at the same time!!
