Link tip and armor surface
Hi all,
For all of you Panther builders I would like you to know about this German Panther web site.
http://www.panther1944.de/panzertruppe.htm
The best on the web if you ask me, but...................it is all in German language
Any how it is full of photos and if needed there is always the AltaVista translation site
One other thing I would like to tell you about is how amazed I am looking at all those Armortek Tigers and no one has consider to take care of the very special surface look of German armor plates
In the smaller 1:35 scale it is no problem and common practice to fix it (described how to do in various books) but here in 1/6th no one bother - so I better change that...............
At my on going Hetzer build I had the same problem but in smaller areas as the kit is a plastic/metal one with the surface taken care on the plastic parts.
How I did is described here:
http://www.armorpax.com/Armorpax/Forum/ ... c.php?t=66
And the result looked like this:
BIG difference from the far to smooth kit steel surface!
The look on the real 1:1 Panther:
And how it looks on a 1:16th Panther
(not my 1:6th! - photos taken from the German web I told you above)
I will do an Early Panther with zimmerit but I will do this armor surface on areas left without zimm (around tools, turret escape hatch and decks)
Hope this inspired some of you to do this
- Been liked: 177 times
Thanks Tim for those kind words
Hope to have the Panther well up to my Hetzer standard, but this all metal kits is all new to me still it is sooooo fun building
Was the forum talking about adding texture on plastic or metal?
On plastic is easy but on metal it is different as it moves more as the temperature changes.
The way I did it I think will work - at least all still seems ok
- Rich Stinchcomb
- Has liked: 3 times
- Been liked: 1 time
- Been liked: 10 times
Kent,
Your texturing looks superb. I guess that on my original Tiger I didn't do the texturing for two reasons one was not knowing what the look was really like and the other was the lack of techniques to do it. I've run my Tiger a great deal and found that the model takes quite a bashing and has developed a patina of its own after a few bumps and scrapes. I take it that the flat top deck and turrert roofs were fairly smooth with only the thick heavy armour exhibiting the "rough" look. I did experiment with using P38 car body filler thinned down with cellusose thinners. It was rapidly painted on the surface and then I found dabbing a sponge over it made an even rough finish. This was then lightly sanded to give the final effect. It worked well in practice but I never did it on the tank as I had fitted too much detail and it really needs to be done on the bare plate first. I am doing a similar effect on my Sherman, hoping to make a higher standard model this time.
Allan Richards
Hi Allan
Thanks for your kind words.
To my knowledge all ww2 German Armor plates had a more or less rough surface - it was from the process in making them.
So that does include the horizontal plates as well.
Please look at this photo of the Late Tiger 1 from Lenio-Sengeri in Russia:
Kent,
I can see the very subtle texture to this plate, which would need carefull replication at 1/6th scale to make it look right. To me its more importatnt to make it look right rather than just to replicate it exactly at 1/6th scale so that overall the model creates the right effect.
That looks a strange photo to me in that the palte is without paint and the welds look new. Is this some restoration project I've missed out on? I had heard that a very delapidated Tiger had been recovered in Russia from an open air location.
Allan Richards
Hi Allan
The Tiger was used for target practise before until someone told them how rare they were................
It is located in an open air museum and has not been inside for 60 years.
Some of the welds are new made to make him look decent.
Here is a link to more photos (sorry if this is off topic )
http://tanxheaven.com/zbc/TigerILenino- ... irizbc.htm
Some of its loose parts have been stolen and in fact the whole tank was for sale on EBay a few years ago.
The man who claimed to be the owner was seen smiling in front of the tank in one auction photo - scary country that Russia!
- Has liked: 1421 times
- Been liked: 1596 times
> the welds look new
According to the Tank Overhaul program, the original welds were done (on the Sherman at least) with a Stainless Steel filler rod, so I would imagine they'll always look better than the aged plate around them.
I've certainly seen heavily weathered Shermans with welds showing brightly through the grime.
- Been liked: 1653 times
