Steves winstones MG
Dale jordan
Been liked: 512 times
Steves winstones MG
Post by Dale jordan »
Can someone Please tell me how Steves MG with the 3V light hooks up to armorteks new sound unit what plug to I need etc . Dale
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hello Dale.
Somewhere on the forum I think I have posted this along with someone else, but here you go first off I have not been able to get the fitted lightbulb to work so you need to remove that and replace with an ultrabright LED then chop one end of a servo extension lead and feed the wires through the M.G. this is a bit of a bugger to do and you may find you need to take the gun apart and replace the main steel tube that goes through the centre as its too tight and not enough material at one end to drill out on the lathe at least thats what I found, then solder the leads to the led and pull back into position with the bulb slightly protruding I find best same as you would on a Tamiya model then feed the wires back through to the sound module where you will see that Mark has fitted a very handy socket for the servo lead to plug into.
All the above sounds a faff but you will see its easy.
Any bother give me a shout and I will always help where I can.
Cheers Paul :wink:
01524 720977
steve winstone
Been liked: 46 times
Post by steve winstone »
Hi Dale & Paul,
I have now fitted a 3V bulb instead of 12V the steel inner barrel is now drilled out to 2mm, and this should enable you to fit the larger wire if you need to fit the LED bulb.
Paul Morris
Hi Steve.
Thats brilliant news, I never liked taking your barrels apart as I was always worried about losing a piece in my very tidy shed :oops: lol
Cheers Paul :wink:
01524 720977
Richie Wignall
Post by Richie Wignall »
Hi Steve & Dale
Great news on the MG 8)
Dale
Just plugs into Thomas's sound card, (plug 6) universal onboard outputs(optional) ether orange to the top or brown for muzzle or mg flash.
i posted this on here a couple of years ago. very easy mate.
Just like Armorteks new units, just plug and play, in fact fool proof :P.
Richie wiggytronics :wink:
r-wignall@sky.com
01772460902
Dale jordan
Thanks everyone I've found your old post ... I'm going to get my stuff sent out today from Steve .. so just to clear one thing up ,will the bulb in steves MG work but it just wont be bright enough ??? Dale
http://www.armortek.co.uk/forum/viewtop ... c&start=30
Chang
Has liked: 16543 times
Been liked: 487 times
Post by Chang »
Dale, how is the MG sound/flashing function going?
With the new Amplifier Module & Auxiliary Module, is the way of wire-connection still the same to make the MG sound synchronized with the flashing bulb? :?:
Any expert tanker’s advice will be much appreciated. Thanks in advance.
L Chang
Richie Wignall
Chang pm sent :wink:
Richie :wink:
Dale jordan
Help Richie and Paul . Because I'm real bad at this stuff , how does this look ? I tried it today and nothing happen is this the right way around ? do I have to reprogram something ?? .... Dale
Richie Wignall
Hi Dale
Try selecting muzzle flash, does it work? if so spin it round again, then it will be mg flash.
Richie :wink:
Been liked: 3689 times
Hi Dale
I believe that the bulbs that Steve supplies are LEDs. If so, they polarity specific. Try reversing your connections to the bulb itself.
Richie Wignall
Hi Guys
Is it a buld or LED? i have tried bulbs before and they didnt work on the sound card, i dilled out to fit a 3mm super brite LED instead, and works great. if you dont want to drill it try fibre optic cable insert, works well too.
So Dale check, i bet its the bulb one. :roll:
Allso on Thomas TBS5 boards you just spin the servo cable plug round for muzzle & MG flash, it will also run 2 MG LED'S aswell.
LEDS i use below, cheap as chips :wink:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Below is two of Steves lovely MG's with the LED's fitted.
Hope this helps
Richie :wink:
Richie Wignall
Hi Guys
If any one is struggling and wants a lead making up please contact me. £8 +£1 p+p. around a 1mtr long cable.
Richie :wink:
P.S DONT NOT SOLDER, WHEN IT IS STILL CONNECTED TO THE SOUND MODULE.
Richie Wignall
Hi Dale
Any luck?
Richie Wiggytronics :wink:
r-wignall@sky.com
Dale jordan
Hi Richie . I've been all over town can't find any 3mm LED'S Also can't find any on e bay Australia . So it looks like I'll have to order them from your link ... I'm looking forward to having the flash working ... Dale
