You're not alone...
I've noticed the problem ever since i started here.
Off course i never talked about it so thanks to you somebody will start talking to...
...you are not alone!
Some days I need to log in every time I visit here while other days everything works fine.
Some days surfing here work fast and fine but other days everything go sooooooooo sloooooooow
Today is sadly one of them "so slow" day.
We are very sorry about the speed of the forum at the moment. Our site is hosted by One.com in Denmark, and we have been advised that they are experiencing some problems at the moment because the equipment is being upgraded. Hopefully a speedier service will resume soon.
Adrian, my experience is that what you describe most likely has nothing to do do with the Armortek side (Server, etc.). I've been checking the forum regularly over recent weeks with no problems, though I might have just been lucky. Check the following:
1. the Browser security settings must enable the accepting of 'Cookies' from the web site you are visiting. So check your Browser settings for that.
2. see if your software is enabled to remember password/username. For example I use Apple Safari and Firefox, after I initially log in then I am asked by the Browser if the software is to remember the password/username and I select 'yes'. If you accidentally clicked "no" then the Browser will not usually ask again when visiting the site and you will not automatically be logged in.
Hope that helps,
Martin
