I installed the option packs 1 and 2 in my Panther and for the most part, all has been straight forward and working well. However, I am having a few new problems after a few dissassemblies and reasseblies of the components.
First one is that my gun elevation stopped working. Motor works fine when switched with turret traverse controller and the gun elevation controller makes its "click" sound when stick is moved for up or down. But it's no go. Any thoughts? One of the wires from the receiver to the controller was out and I put it back in but still nothing.
My second problem is the smoke generator fan/speed controller. It works but the motor needs to be at about 80-90% speed to get the fan to kick on. Is this normal? Smoke coming out of the exhaust pipes seems to be either on or off. It'd be great to get more smoke at a lower speed. Is this possible? Is the fan supposed to operate at varying speeds?
Thanks so much
