222
karl schneider
222
Post by karl schneider »
Hi all
my nane is karl and i have a 222 and i am looking for a 20mm mags for the gun can any one put me in the right directions
thanks karl :?
leesellars
Been liked: 15 times
Post by leesellars »
Hello Karl
What type do you want? Cases or the Bannana Mags. Give me a ring see website.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Robin Ellis
Been liked: 8 times
Post by Robin Ellis »
Karl, I had to buy a complete pak 38 kit with figure on E-Bay and then cut the cases down to fit the breach.See in the for sale section my 222. I sold the figure seperately, and then fitted the metal pak onto the 222 gun mount. together with a DID metal MG 42. The cases should be straight for the 222 not curved!
Ad Wouterse
Been liked: 2 times
Post by Ad Wouterse »
Hi Robin,
The short, 10 rounds, mags for the KwK 38 on the 222 are not straight but still slightly curved.
The scaled mags that are available on the market, are in fact the long 20 rounds versions for the FLAK 38. Clearly these will not fit on the 222 unless they are modified as described by you.
Source: Panzerspähwagen, Feist & Johnson, Ryton Publications
Ad
colin fairweather
Been liked: 9 times
Post by colin fairweather »
hi all
i have just about all the extra detail parts i need for when i start building apart from the main gun does anyone know where i can get it by its self i have searched most sites but to no avail as of yet :(
thanks
colin
Ad Wouterse
Been liked: 2 times
Hi Colin,
I think it will be very difficult to find the Flak 38 as a separate item, and if you do it will cost you almost as much as the complete kit that it belongs to.
Check with Lee Sellars if he can help you with this kit http://newthorpemodels.co.uk/component/ ... ,18/hit,1/ . It is a beauty :wink:
Ad
colin fairweather
Been liked: 9 times
hi ad
ye im starting to think that i just hate buying stuff i dont need it ends up sitting on the shelf i might have to get the lathe working when i start building it
colin :)
Ad Wouterse
Been liked: 2 times
Hi Colin,
Just remembered something :roll:
The separate Flak 38 (without the dol... I mean Action Figure) is available from www.war-toys.com . Search the left pane menu for DragonWWII, boxed Dragon 1:6thWWII, Marcus Holzhammer .
Still some useless parts included, but only USD 79,95.
Ad
colin fairweather
Been liked: 9 times
spotted that one thanks its kinda will i wont i situation :roll:
colin :)
Robin Ellis
Been liked: 8 times
Gentlemen, as you can see from my photo, the mags have been cut down to fit the breech, and they are still slightly curved!
Has liked: 1363 times
Been liked: 1556 times
Where did the used rounds from the guns go ?
I can't imagine they just fell into the vehicle.
Was there some form of gurtsack arrangement ?
Ad Wouterse
Been liked: 2 times
Adrian,
The spent shells went into the "spent shell shute".
That is the part just above the right hand of the figure in the above picture from Robin. I have seen pictures where a kind of "sack" was attached to the bottom of the shute.
Ad
Robin Ellis
Been liked: 8 times
A better photo of my magazine mods.ROBIN
Were the MG casings directed to the same shute ?
Also, when belt fed guns like the MG and US .30 and .50 cal models are fired, does the belt leave intact or does the gun spit out the cartridges and links separately ?
Robin, thanks for the closeup.
Ad Wouterse
Been liked: 2 times
When a MG is belt-fed, the empty shell remains in the belt link. In most German AFV's the belt and shells were led back into an empty "gurtsack".
As mentioned earlier, a big sized type of "Gurtsack" could be attached to the underside of the shute/deflector to collect the empty 20 mm, shells.
On the below picture you can see part of this device. It is the green piece of cloth below the shute,
Ad
