Stencil of SS for my King Tiger
duncanallender
Been liked: 8 times
Post by duncanallender »
Hello all,
I'm looking for 1/6th stencils to do crossed keys and the laurel wreath below. Does anyone know where I may find these.
Look forward to hearing,
Duncan
NordWest KampfGruppe
Richie Wignall
Post by Richie Wignall »
Hi Dunc
I knew Ant had some a couple of years ago , he may still have them :roll:
Allso Dave Dibbs at Armorpax use to sell them i think he still does.yep below :P
http://www.armorpax.com/Armorpax/WWII%2 ... 20Sets.htm
Richie (wiggytronics) :wink:
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Hi Duncan,
If you are just after the Crossed Keys then my Budget stencil is probably best.
Cheers for the plug Richie.
Dave
www.armorpax.net
Antony Rowley
Location: Back to Wirral home of the brave or not so brave, England
Post by Antony Rowley »
Hi Dunc,
Clive has my set. You're very welcome to use them too mate :wink:
Maybe send Clive a PM as he's always extremely helpful :wink:
Thanks Ant
Dale jordan
Been liked: 497 times
Post by Dale jordan »
Dave Can you please tell us how you use your stencils ...eg do you cut them out in the order that you need ? then tape them into postion ? and mask around to stop over spray , also how about the cross which part do you do first the centre part or the outline ? which colour do you paint first black of white ... Dale ..
Hi Dale,
The stencils should be cutout and used individually, I never spray but use a wide flat brush, cut short, so its like a full size stencil brush. I hold the stencil where I want and then stipple the paint in , normally Vallejo acrylics. Make sure there isn't too much paint on the brush and try it out till you get the right amount. This is the closest method I could get to recreating the "feel" of field applied stencils.
If you wish to spray just use masking tape around the stencil and mask enough area to avoid overspray.
With the Cross I put the middle on first then position the outline and add that.
Hope this helps.
Dave
www.armorpax.net
