Mid Tiger rebuild
David Brady
Has liked: 216 times
Been liked: 840 times
Mid Tiger rebuild
Post by David Brady »
Hi
Here is my mid tiger that i bought second hand, over the next year or so i will strip down to components and rebuild.
best of luck david,i've rebuilt a second hand one myself,rusty,bolts snapped,and no metal work experiance,but enjoyed it! post some photos. simon manning
David Brady
tiger
Hi Simon
Not looking forward to rusty snapped off bolts or that the torsion bars have been welded to suspension sharfts :cry:, With alot of help and accessories from Steve Winstone my tiger will live again. If my rebuild turns out half as good as your mid tiger, it will be a job well done.
hi david,my tiger was abandoned due to the owner passing away, left in a shed open to the elements for nearly two years,which did;nt help,,it looked very sad when i purchased the tiger,my wife said ;how much!..for that...
David Brady
Mid Tiger Rebuid
Hi
A few more pics of my tiger strip down, all went well no snapped off bolts
Brian Leach
Been liked: 3 times
Post by Brian Leach »
It almost looks sad, seeing her stripped down so :)
Good luck with your project, Brian
Has liked: 163 times
Been liked: 849 times
Lots of gunk inside the hull. Yek! I'm looking forward to the rebuild - the first build didn't do these great models justice. Good luck on the rebuild and keep us posted David.
those photos bring back memories,now you can't go back,keep the posts coming, simon manning.
David Brady
Re: Mid Tiger rebuild
Hi I have been working on this tank when ever I get some spare time, so progress is slow, I have lowered the rear deck, which has been quite difficult with basic hand tools, I just need to add rear supporting brackets and this job will be complete. New torsion bars added I will set suspension angle slightly different towards the rear to stop sagging.
Bump stops fitted and suspension mount moved, fillet detail added.Image
Support brackets added.
Track guard added, is this in the right position for a mid tiger, I do most of my repositioning by eye.
New boss and repositioned.
Track bar added and casing fillet reshaped.
David Brady
Hi, more progress.
Tow bracket added, I have been trying to replicate accurate welds, let me know if these look ok.
Regards David
David Brady
Hi, I have fitted a set of water and fuel filler caps, fair bit of work involved.
Regards David
the filler caps look well fitted dave, whats the hurry! once youv'e finished you will only buy another, keep going regards simon.
Has liked: 1490 times
Been liked: 1697 times
Nice to see another old girl getting a makeover :D
I notice this one still has the cast swing arms - might be worth checking them :wink:
David Brady
Hi, a few more improvements made
Reduced the overhanging edges of the upper front.
MG position has been corrected by fitting new front glacis.
New suspension arms fitted.
Fitted new hatch rings to the deck.
now i have seen your radio/drivers hatch rings inserted i will have to install these aswell, a quality construction in the making, keep the posts coming it reminded me of what i missed, regards simon.
