Runnaway
Runnaway
Im bench testing my motors, and I notice that if I turn off the radio before the fuse box that the motors will start running on their own. Is this normal? Seems a little dangerous with the weight involved.
Also if I plug my reciever battery into the fuse box it wont work, that I have to plug it into the reciver like a normal rc setup.
- Been liked: 177 times
Im just working on my Pz4 right now, I could imagine my Panther or a Tiger, it would knock your door down. Definatly going to have to keep a close eye on our 5 year old, might find him flattened into the lawn. He will have to stick to the Stuart for now.
- Been liked: 2 times
I have the battery issue resolved, it must have been something like Ad mentioned.
But I have one remaining problem, and I think it is a faulty controller box. Im hoping not, because of the delay it will cause in sending it back.
One of the drive motors I cannot stop. I can reverse its direction at will but I will never stop unless I cut the power.I switched the wires of the two controllers and the problem followed to the other motor.
I switched the channels on the radio and the problem followed to the other stick. Im all but ready to pack it up for the UPS man unless somebody has an idea.
On the bright side I am very happy at how I can crawl the one motor along, I just hope this is the case as well when it is pulling 150 pounds. Im sure it will be.
- Been liked: 4 times
Ouch Mike.
Yes Ad I tried that, I even tried a different radio, people kept telling me it was my spectrum radio, but where the controller goes the problem follows.
I think the verdict is in.
"If I die in a combat zone, box me up and ship me home"
Last edited by Roland Wallick on Mon Oct 08, 2007 1:12 am, edited 1 time in total.
Roland
When the radio was turned off, VROOOOOOOOOM! Motor would go as you describe in your post. I just assumed this was normal and have since changed the way I shut things down after running. Maybe I missunderstood your posts and you are describing something else.
Everything runs great while operating the tank.
Oh I thought you had a bad controller.
Yes I guess this is normal for the Armortek setup, (the runaway syndrome) but Ive never experienced it in any other rc applications. Lucky I discovered it with my parts strewn all over the floor rather than assembled in the tank. I did read it in the manual but didnt think anything of it.
Hi guys,
After more than 40 years of RC experience (yes, I started with the famous tip-tip radio sets) I was under the impression that the standard turn-on/turn-off procedures were used worldwide.
Any RC vehicle may take off on its own if you do not follow the standard procedure and there is some radio interference in the air. If it hasn't happened to you, well I guess then you have been lucky
Ad
Ad
