Barrel Assembly
Forum for discussion relating to the 88mm Flak36
Colin Richards
Has liked: 4 times
Barrel Assembly
Post by Colin Richards »
I have a slight problem and would welcome advice. What stops the barrel from sliding off the gun cradle assembly? Had I not used a strong loctitie thread lock on the barrels I would have put a captive spring on the recoil rod. The other option I have thought about is to use the lower bracket with a bolt drilled up through the base of the slide trough to act as a buffer.
Any suggestions or solutions would be greatly appreciated?
Colin
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
Post by Jeffrey Goff »
Hi Collin, its been awhile since I finished the 88, but I used a compression spring with the rod running through it, this had a disk on one end, it allowed the barrel to travel backward and then return under its own power
regards
Jeff
Colin Richards
Has liked: 4 times
Hi Jeff
I thought that would be the best solution but I'm not sure how to get the spacer tube and recoil block undone as the thread lock that I used was Loctitie 638. I have done a lot of work on the block and I'm worried that if I use mole grips I'll cause a lot of damage.
Colin
Derek Attree
Has liked: 218 times
Been liked: 183 times
Post by Derek Attree »
Colin
To release loctite's you con sometimes free it with heat
or try acetone
Hope this helps
Has liked: 1419 times
Been liked: 1594 times
Derek's suggestion of heat is the best method.
From the Loctite 638 data sheet:
For Disassembly
1. Apply localized heat to the assembly to approximately 250°C. Disassemble while hot.
Colin Richards
Has liked: 4 times
thanks to you all for your help. I'll give the heat a go
Colin
