I have a slight problem and would welcome advice. What stops the barrel from sliding off the gun cradle assembly? Had I not used a strong loctitie thread lock on the barrels I would have put a captive spring on the recoil rod. The other option I have thought about is to use the lower bracket with a bolt drilled up through the base of the slide trough to act as a buffer.
Any suggestions or solutions would be greatly appreciated?
Colin
Barrel Assembly
- Has liked: 4 times
- Has liked: 20 times
- Been liked: 737 times
- Has liked: 218 times
- Been liked: 178 times
- Has liked: 1363 times
- Been liked: 1556 times
