King Tiger Build
- Been liked: 1644 times
King Tiger Build
While i am Waiting for some electric parts for my early tiger i couldnt resist but open my king tiger, and start it off.
For those who like substantial metal,this kit has it!
Very Heavy..and well made.
- Been liked: 10 times
- Been liked: 1 time
- Been liked: 2 times
- Been liked: 177 times
- Has liked: 129 times
- Been liked: 773 times
nice to hear from you robert,i have ground to a stop already,when i start a kit i confess i know nothing about what im going to make,learning on the way is part of the attraction for me,not being a tank buff thats why the forum comes in so handy.i will try and post somthing interesting.
regards simon manning
- Paul Wills
- Has liked: 646 times
- Been liked: 141 times
Hi Simon,
I like what you are doing with the light, I might try that myself. Question for you, are they 10ba bolt you are using to secure the deck down? if they are, are the standard or small heads, I noticed on the photo that Kent has posted, the original had hex headed bolts so I was considering to do that myself, how does it look?
Paul .
Paul .
King Tiger Build
so far so good,
outer nuts and bolts 7ba x1/2 "hex standard steel bolts+7ba standard steel nuts,12 per wheel,nut and bolt.
middle section of wheel 15 nuts and bolts,7ba small head shank x30mm long with 6mm of 8ba thread on the end for 8 ba nut,this combination allows you to copy the correct nut and bolt pattern if you want ,i will use the template to correct the missing holes ,the 30 mm bolts replace the kit ones supplied the 7ba shank gives the same thickness as the 2.5mm and fits well in the holes provided,this nut and bolt size look quite good.
the inner wheel hub,i used 10ba x 1/4 hex steel nuts and bolts x 6 of each per hub.
e.k.p.supplies made all the nuts and bolts and the 30mm long specials ,they will make more no problem if required.
clear as mud. simon manning
- Has liked: 1419 times
- Been liked: 1594 times
After some wheel construction, i think a 7 BA thread on the end of the 30mm long bolt would be more substantial. The 8 BA thread seems a little to fine.
you can get a 7 BA small nut to match the bolt head, so as to keep the bolt pattern consistant in size and to gain a bit more added strength without loosing the scale on the wheels. i am going to order this size difference for EKP and try them.
