Benedini sound system
Has liked: 1024 times
Been liked: 2093 times
Could anyone help me with the installation of the Benedini rotary encoder switch into a 7C Futaba transmitter? The switch comes supplied with a standard rx connection but I can't see how to get to the appropriate input leads on the tx. The photos below show the encoder and the right hand stick pots. It looks like there is a white coloured plug attached to the pot on the stick but I can't see how to get at it and establish whether it's the correct lead.
Someone must have done it - please help an electronics dummy.
Thanks. Stephen
Ad Wouterse
Been liked: 2 times
Post by Ad Wouterse »
Hi Stephen,
The servo connector from the rotaty encoder has to be plugged into a free proportional channel on your TX. A switch (on/off or on/off/on)channel will not work.
I am not really familiar with the 7C, so I don't know if there is a free channel available. If not, you may have to sacrifice one of the 4 channels connected to your joysticks.
Good luck.
Ad
leesellars
Been liked: 15 times
Post by leesellars »
Hello Stephen
Caution :!: :!: .This is a digital Transmitter and is different to the Mhz set.I have been told that you have to unsolder the rotary switch and solder the encoder onto it. I havent done it yet but i know who has. John Davis has done it to all of his tanks.
When you have done it you have to reprogram the sound card to recognise it and then reprogram it again to put your sounds on it
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Mick Regan
Has liked: 34 times
Been liked: 6 times
Post by Mick Regan »
Hi Stephen
If you PM me you email address, I have photos of each step which I can send you. If you need a narrative as well, I'll do my best. 8)
I am planning to post a "How to" for the decoder installation on the forum, but I'm afraid work keeps getting in the way :!: :lol:
Mick
Ad - yes, I was referring to the y axis on the right hand stick which I currently use for sound. The rotary switch is an easier interface than trying to count stick displacements. Lee - thanks for the steer to John. I've also asked Thomas if he's had any info. I'll post any reply I get.
Mick - wonderful news. Thanks. Pm sent. Regards. Stephen
