hi all
after running my tigger for about an hour or so today i checked the voltage of both batts each and then linked which i dont normally do and found something odd or maybe not i'm not sure
, one read 12+volts and the other 7+volts, then linked they read 19+volts at the motors this is not right is it ? shorley the batts should run down evenly together, i have noticed she runs slower than she did 4+mph. speed controllers are set at full.
any ideas
thanks
colin
