battery voltage
colin fairweather
Been liked: 9 times
battery voltage
Post by colin fairweather »
hi all
after running my tigger for about an hour or so today i checked the voltage of both batts each and then linked which i dont normally do and found something odd or maybe not i'm not sure :? , one read 12+volts and the other 7+volts, then linked they read 19+volts at the motors this is not right is it ? shorley the batts should run down evenly together, i have noticed she runs slower than she did 4+mph. speed controllers are set at full. :?
any ideas
thanks
colin
leesellars
Been liked: 15 times
Post by leesellars »
Hello Colin
It sounds like you have a duff battery.Try puuting a full charge on both and then check the voltage after a week.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
colin fairweather
Been liked: 9 times
thanks lee
i'm starting to think that myself :( will charge them up first then run them down and charge again to see what happens, i dont know why only one battery is running down though, :? but i still have runnung voltage at the motors 19+v :?
thanks
colin
