OPEN ON THE 6TH FEB 2025
Electrical boxes on front plate
Erichornby
Been liked: 1 time
Post by Erichornby »
Hi Gents, totally new to this subject so probably a daft question. If I mount the electrical boxes CV0629 and 629M onto the front plate CV0104, it covers the top mounting screw hole. If I mount the plate the idler block covers the screw holes for the electrical boxes. Do I just stick in place?
Eric Hornby
Andre Meylan
Has liked: 682 times
Been liked: 300 times
Re: Electrical boxes on front plate
Post by Andre Meylan »
Erichornby wrote:
Mon Dec 30, 2024 11:39 am
Eric Hornby
Hi Eric,
you are right, this is a dilemma. I will certainly use the 4 screws to fix the front plate and glue the 0629 elements onto it. One also needs to drill a hole into the plate for the wires or one modifies the idler block before mounting everything. I don't see another way myself.
Best regards, Andre
chris fry
Been liked: 403 times
Post by chris fry »
Hello Eric,
There are grub screws in the electrical boxes that locate the boxes on the front plate, There is a fastener on the inner side of the mudguard that locks it down, Also where the cable comes through for the light runs under the mudguard then back through the hull side,
Chris.
Andre Meylan
chris fry wrote:
Mon Dec 30, 2024 3:46 pm
Hello Eric,
Chris.
Thanks Chris - you just saved me from making a terrible mistake ... !!! Cheers, Andre
Erichornby
Been liked: 1 time
Many thanks Chris and Andre. All is revealed, mounting could have been better understood if the locating holes for the M3 grubscrews had been blind drillings. Having a through hole with a countersink, apparently for a screw had me well confused. Again, many thanks.
Eric Hornby
