Steel Tracks
Richard Goodwin
Has liked: 294 times
Been liked: 291 times
Steel Tracks
Post by Richard Goodwin »
Hi everyone.
I have a set of steel tracks fitted on my Panther that I need to take off to repair some tyres and possibly a bearing but not sure how to do it. The following is a picture shows how the links are connected :
I believe thier to be a split pin behind the cap but not sure since I can’t remove the cap. Does anybody know about this type of track; grateful for any assistance. TIA
David Brady
Has liked: 216 times
Been liked: 840 times
Re: Steel Tracks
Post by David Brady »
Hi Richard,
Should be a pin as pictured on my steel tracks
Hope this helps
DB
Richard Goodwin
Re: Steel Tracks
Hi Dave,
Many thanks for the reply.
Looks the same sort of track but I definitely have no visible pins.
David Brady
Re: Steel Tracks
OK- if no pin in the hole try some heat... maybe glued on.
Paul McMartin
Has liked: 508 times
Been liked: 170 times
Re: Steel Tracks
Post by Paul McMartin »
Are you sure they don't have roll pins. Look closely to see if there is a gap in the hole on the collar. If so, you will need a pin punch to remove.
Roll pins.png (44.85 KiB) Viewed 1441 times
Richard Goodwin
Re: Steel Tracks
Thanks Dave and Paul for your suggestions.
Decided to initially apply a little heat and with a screwdriver, gently eased the cap off
If you look close enough, with the cap removed, you can see the end of a pin at the edge of the hole.
It seems a good way of doing it but it would mean carrying a blowtorch around in case you need to remove the track. There are pros and cons to the method!
Now for those much needed repairs 🤫
Has liked: 1495 times
Been liked: 1699 times
Re: Steel Tracks
A pin punch would be the ideal tool. You would need to support the track so that as much force as possible went onto the pin.
If doing it in the field, I would probably replace with a cotter pin until I could get it home.
Liam offered a choice of roll pin or split pit with his steel KT/JT tracks.
Marco Peter
Has liked: 1540 times
Been liked: 798 times
Re: Steel Tracks
Post by Marco Peter »
One can only admire with awe the detail on those tracks... :D
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
Jae-seung Roe
Has liked: 316 times
Been liked: 134 times
Re: Steel Tracks
Post by Jae-seung Roe »
Is your steel track from Vincent's one?
Richard Goodwin
Re: Steel Tracks
Jae-seung Roe wrote:
Tue Oct 01, 2024 5:53 pm
I believe it is yes!
Richard Goodwin
Re: Steel Tracks
Marco Peter wrote:
Tue Oct 01, 2024 5:23 pm
it is incredible.....trouble is, you have to get on ya knees to see it :wink:
