Hi everyone.
I have a set of steel tracks fitted on my Panther that I need to take off to repair some tyres and possibly a bearing but not sure how to do it. The following is a picture shows how the links are connected :
I believe thier to be a split pin behind the cap but not sure since I can’t remove the cap. Does anybody know about this type of track; grateful for any assistance. TIA
Steel Tracks
- Richard Goodwin
- Has liked: 292 times
- Been liked: 285 times
- Has liked: 182 times
- Been liked: 706 times
- Richard Goodwin
Re: Steel Tracks
Hi Dave,
Many thanks for the reply.
Looks the same sort of track but I definitely have no visible pins.
- Paul McMartin
- Has liked: 310 times
- Been liked: 97 times
Re: Steel Tracks
Are you sure they don't have roll pins. Look closely to see if there is a gap in the hole on the collar. If so, you will need a pin punch to remove.
- Richard Goodwin
Re: Steel Tracks
Thanks Dave and Paul for your suggestions.
Decided to initially apply a little heat and with a screwdriver, gently eased the cap off If you look close enough, with the cap removed, you can see the end of a pin at the edge of the hole.
It seems a good way of doing it but it would mean carrying a blowtorch around in case you need to remove the track. There are pros and cons to the method!
Now for those much needed repairs
- Has liked: 1381 times
- Been liked: 1578 times
Re: Steel Tracks
A pin punch would be the ideal tool. You would need to support the track so that as much force as possible went onto the pin.
If doing it in the field, I would probably replace with a cotter pin until I could get it home.
Liam offered a choice of roll pin or split pit with his steel KT/JT tracks.
- Marco Peter
- Has liked: 1397 times
- Been liked: 782 times
Re: Steel Tracks
One can only admire with awe the detail on those tracks...
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
- Has liked: 272 times
- Been liked: 129 times
- Richard Goodwin
- Richard Goodwin
Re: Steel Tracks
it is incredible.....trouble is, you have to get on ya knees to see itMarco Peter wrote: ↑Tue Oct 01, 2024 5:23 pmOne can only admire with awe the detail on those tracks...
