Whilst running my panzer111 this weekend
The sound started to fade away then disappear
Altogether, has anyone else had this problem
And can it be fixed
T5 audio module
- Been liked: 1 time
- Has liked: 1481 times
- Been liked: 1687 times
Re: T5 audio module
Do you mean the TBS5 ?
The last two sounds, 11 and 12 from memory, are software driven volume controls.
If you select I believe 11 is volume down and 12 is volume up, but it's a long time since I've used a TBS5 based system.
Try selecting sound 1, so that the engine sound should be playing. Then select and hold sound 12, as if you wanted it to repeat, and see if the volume returns. If that doesn't work, try doing it with sound 11.
Re: T5 audio module
Hi Adrian do you mean selecting the sound on the 3 way
Switch on the transmitter
Re: T5 audio module
Yes.
Re: T5 audio module
Great
