T5 audio module
David Gray
Been liked: 1 time
T5 audio module
Post by David Gray »
Whilst running my panzer111 this weekend
The sound started to fade away then disappear
Altogether, has anyone else had this problem
And can it be fixed
Has liked: 1475 times
Been liked: 1674 times
Re: T5 audio module
Do you mean the TBS5 ?
The last two sounds, 11 and 12 from memory, are software driven volume controls.
If you select I believe 11 is volume down and 12 is volume up, but it's a long time since I've used a TBS5 based system.
Try selecting sound 1, so that the engine sound should be playing. Then select and hold sound 12, as if you wanted it to repeat, and see if the volume returns. If that doesn't work, try doing it with sound 11.
David Gray
Been liked: 1 time
Re: T5 audio module
Hi Adrian do you mean selecting the sound on the 3 way
Switch on the transmitter
Re: T5 audio module
Yes.
David Gray
Been liked: 1 time
Re: T5 audio module
Thanks Adrian , selecting position 11 and holding
Has rest it👍
David Gray
Been liked: 1 time
Re: T5 audio module
It’s reset works fine now
Re: T5 audio module
Great :D
