Sdkfz Famo
- Been liked: 49 times
- Peter Quambusch
- Been liked: 1045 times
Re: Sdkfz Famo
Hi Roy,
A Knight´s Cross holder on a Famo???
That is more a job for a sergant or so...
Peter
Peter
Re: Sdkfz Famo
HI Peter thanks for your reply never bought any figures in this scale just looking for ideas but liked the look of the figure need a driver for my famo if you have any ideas where to buy. Cheers Roy,.
- Peter Quambusch
Re: Sdkfz Famo
Hi Roy,
Have a look on the web for 1/6 action figurrines. There are a bunch of retailors and also privatly sold ones on ebay. Good brands are Dragon or DID, just to name a few.
For the Famo you should look for a guy in regular uniform, not Panzer black. Camo is also good. Depending on your vehicle either from Luftwaffe, Wehrmacht or Waffen SS. There are several figurines on the market.
In case of more questions, just ask.
Peter
Peter
- Chris Hall
- Has liked: 536 times
- Been liked: 688 times
Re: Sdkfz Famo
Staggeringly expensive
Keep looking - you should find an appropriate figure for around £80 on eBay (other auction sites may be available
- Peter Quambusch
Re: Sdkfz Famo
Hi Roy,
This one would fitt much better!
But like Chris said, very expensive...
Peter
- Been liked: 741 times
Re: Sdkfz Famo
Hello,
I did buy some guys for my famo about 5 and 2 for my sdkfz 251
And these dolls cost a lot today
also hard to find some of them.
Best regards Yves
Best regards Yves
- Chris Hall
Re: Sdkfz Famo
Roy -
I'm not pretending to be an expert on German uniforms
. But, based on my limited knowledge and Peter's comments, a quick flit around eBay offers up the following, which I think would fit the bill:
https://www.ebay.co.uk/itm/156168964401
https://www.ebay.co.uk/itm/364105199593
It's not the accoutrements you're after, it's the basic uniform. And, if it doesn't quite work for your chosen unit, you can always 'kit bash' - there are loads of single bits out there, hats, tunics, badges etc.
The reason some of these figures are outrageosly expensive is that they were designed to be collectors' items, to be kept pristine in their boxes, not to be driven around in a model tank ! So rarity, desirability and release date becomes a factor. You want to find one that's relatively common, and ticks as many of the boxes as possible. Then you can amend it to be unique to you and your ideas.
Good luck !
Good luck !
