KIT No. 98 BUILD
Forum for discussion relating to the 1948 - 1950 Series 1 4x4 car
mick whittingham
Has liked: 10 times
Been liked: 226 times
Re: KIT No. 98 BUILD
Post by mick whittingham »
Spent the day wrestling the body work and cab floor into submission.
I've found it easier to pop rivet the pieces together then bolt into the chassis rails.
Doing this i have a nice sturdy construction with no rattles and a nice solid sound when I tap it.
I'm just trying to decide how best to paint these separate items; paint them off the vehicle and risk marking them as I bolt them into place, or paint the underside, fit to the chassis and mask before spraying the finish coats?
I'm sure it will all come together in the end.
mick whittingham
Has liked: 10 times
Another project within the wider build today.
While fitting the cab floor I thought a handbrake would look good. Nothing too flashy, just a turned rod fitted to the seat panel to the drivers left.
But I got absorbed in the idea and it kind of grew into a functional lever on a sprung pivot so that it can be set at an up or down position. Oh and I just had to make the release button something you could press.
It is a bit in the way of the drive battery but nothing that is causing a problem.
Charles A Stewart
Has liked: 512 times
Been liked: 933 times
Post by Charles A Stewart »
Very nice addition Mick.
I made my handbrake the on/off switch for the electrics :)
Take care.
Charles
mick whittingham
Has liked: 10 times
I was looking at that Charles but I concentrated on the spring detent. I guess it could make it again, but I tend to make things up as I go along and try to do things in one take lol.
I made a new gear lever base and knob this afternoon too, which looks good. I'll post a photo tomorrow.
mick whittingham
Has liked: 10 times
This is the new gear change lever and base, there are a few different designs on the various models.
I like the look of this one so chose to do it on mine.
mick whittingham
Has liked: 10 times
Continuing with the controls I made the high, low range
Lever in a similar way to the others.
I made an alloy base for it to pivot in and hopefully carry a microswitch to activate the electrical system.
mick whittingham
Has liked: 10 times
I thought about Charles idea to power the electrics using the hand brake. Having already done that assembly I decided to use the Hi-Low range lever instead.
Fitting a microswitch and return spring was relatively easy. But I needed a way to keep the switch in the off position when the model is static.
So I set a magnet into the gearbox housing to retain the lever in the forward position, then spring tension holds the switch on for running.
mick whittingham
Has liked: 10 times
Thanks to a clock repair that was handed to me I've been neglecting the build for a few days.
But I finished the spare wheel carrier off and moved a step nearer to painting I guess.
mick whittingham
Has liked: 10 times
I've been working on the cab floor assembly, filling and painting to get it looking good ready for the finish colour.
I'm happy with the gear levers, hand brake and pedals.
Now it's time to look at the seats and any modifications I need to do.
Then finish the rear load bed and body panels.
Feels like I'm really making progress now, looking forward to building my spray booth for the body panel painting.
mick whittingham
Has liked: 10 times
Getting to the point of painting i decided to avoid it for a while and step back to my hand tools.
I thought a pair of pliers might be a fun project to have a go at.
So, a square bar of CCI was sliced into a 7mm thick slab and half of a pair of pliers was drawn on it.
Roughly cut out with a hacksaw then shaped with needle files.
When I was happy with the profile I cut the part in two with a junior hacksaw to give me two identical pieces.
I'm now at that point and looking at how to machine the pivot point on each piece to create a functioning tool.
mick whittingham
Has liked: 10 times
Back to some tin work.
I have had the body panels capping on my radar for a while. I don't like the brass fret so I decided to redo the metalwork in galvanised steel.
Rather than try to do the whole thing in one piece I made separate corner and end caps.
Now I just need to make lengths of U section to run between each cap.
mick whittingham
Has liked: 10 times
So the series 1 tool box beckons again and I finished the pliers off. The first set snapped at the handle as I took out too much meat. So I started again and made them stronger this time.
With those out of the way i looked at the movable jaw spanner included in the original tool kit.
A bit of profile filing and milling on the fixed jaw handle and shaping of the moving jaw.
mick whittingham
Has liked: 10 times
The movable jaw wrench is complete and is shown here with the pliers.
Has liked: 161 times
Been liked: 849 times
Nice work on your Rover Mick - those tools are awesome!
Chris.Marshall
Been liked: 40 times
Post by Chris.Marshall »
Given the size of the original King Dick shifting spanner, I'm guessing it's 1" long? Nice job ! You'll need to dip it in some 'Black it' to get that nice acid black colouring 8)
C,
