Panzer IV Build 002
Nick Farrugia
Re: Panzer IV Build 002
Post by Nick Farrugia »
HI Ray
looking goooood :D is the tank resting on its suspension or is it proped up on something still, i,m only asking because mine is still jacked up and i was wondering how far the suspension settles keep the pics coming all the best ,,,,,,,,,,,,,,,,,,,,,,,,nick
John Fitzsimons
Has liked: 6 times
Been liked: 822 times
Post by John Fitzsimons »
Looking good Ray.How many links did you use on the tracks. Bet you are looking forward to seeing it moving.
Ray Brown
Has liked: 26 times
Been liked: 103 times
Post by Ray Brown »
thanks guys.
nick - its on the running gear now and has been for about and week or two.
john - 98 link pers side as the manual suggests. yep, hanging for the motion pack. just recieveds my spektrum 11channel rc tx. can never have to many channels can you.
got to make fake bolts for the other side. 2mm screws with nuts loctited then body filler to fill the indent followed by sanding & paintinf. a tedious job but the outcome worth it. especially when you want small scale hex head bolts.
John Fitzsimons
Has liked: 6 times
What fake bolts are you making. I have been working on miniature castellated nuts. I have 3 or 4 sizes at present. They are brass but I might cast some dummys in white metal. Try method is to solder two nuts together. File down the joint then cut the castellations with a hack saw. I have been looking at the kit but trying not to start. Have just started on detailing wheels and gear cases.
For small brass or steel hex heads I use bolts from micro fasteners.
Ray Brown
Has liked: 26 times
Post by Ray Brown »
g'day all interested persons. posting my unpainted amature newbie fake welds attempt. comments good & bad (contructive replies) welcomed. i want to look semi authentic.
083 17-03-12.JPG (126.32 KiB) Viewed 8399 times
084 17-03-12.JPG (128.85 KiB) Viewed 8399 times
085 17-03-12.JPG (129.23 KiB) Viewed 8399 times
Ray Brown
Has liked: 26 times
Post by Ray Brown »
086 17-03-12.JPG (128.46 KiB) Viewed 8399 times
Nick Farrugia
HI RAY
Those welds look great to me nothing wrong with them at all very good :D i didnt go with all the welds on mine ,too impatiant i think your build is coming on realy well nice to see it ,all the best ,,,,,,,,,,,,,,,,,,,,,,nick
phil fitzpatrick
Been liked: 223 times
Post by phil fitzpatrick »
Hi Ray
I agree they look fine from your pictures and you will be pleased with them
when they are painted :)
Your Panzer 1V is looking good.
Ray Brown
Has liked: 26 times
Post by Ray Brown »
gday all. i gave the p4 a test run with the motors. one word 'awesome'. next step is to install traverse, elevation, smoke & sound.
chewers
Nick Farrugia
Hi Ray
sounds good not even ordered my extras yet ,keep up the good work.
All the best ,,,,,,,,,,,,,,,,nick
Steve Lewington
Has liked: 8920 times
Been liked: 340 times
Post by Steve Lewington »
Hi Ray
She is looking really good mate.
I have been following your build with great interest and your doing a fantastic job well done.
All the very best
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
Ray Brown
Has liked: 26 times
Post by Ray Brown »
g'day all. motrs fitted, exhaust fitted, sound fitted and all works well. now its time to finalise the build details and painting wethering etc.
has anybody have their milliput fake weld crack between joins after driving/?
Has liked: 162 times
Been liked: 849 times
Ray,
Milliput is a bit brittle once hardened and may chip or flake off. It could crack if the joint is not tight and the plates are moving. I wouldn't think it would crack under normal stress if everything is not flexing. Perhaps it was a bit too dry when applied? Use a litte more water to make sure it bonds next time. Even so it has its limitations, its more a static filler than a flexible adhesive. On the good side it should be easy to patch and repaint if the crack really bothers you. Otherwise it won't hurt anything to be cracked. I like milliput for zimmerit, it makes a tough finish.
Looking forward to seeing your P4 painted and weathered. I'm expecting my P4 to arrive in the next few weeks. I have enjoyed yours, Nick's, and Gunther's Pz4 builds a lot. Keep up the good work!
Ray Brown
Has liked: 26 times
Post by Ray Brown »
thanks bob. as for my paintiing & weathering, don't expect any piccasso....... :lol:
cheers
ray
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Ray
I use Gripfill for my welds it is in a cartridge and the one you want is the green one
with the solvent in it.
It injects in a line and as its a glue it sticks real well. and you get about 15 mins to tool it.
When its fully dry about 2 days it takes paint as well.
Hope this helps
