Jagdtiger No.41 in Germany
florian rudolf
Has liked: 297 times
Been liked: 645 times
Re: Jagdtiger No.41 in Germany
Post by florian rudolf »
Verry nice work on the LiFePo. Did you 3D print the hull?
Florian
Gerhard Michel
Has liked: 3 times
Been liked: 687 times
Post by Gerhard Michel »
Hi Sascha,
why did you use 10 Ah cells to reach 30 Ah? 8 rectangular cells would be some easier to wire and would need less space, I mean.
This is my battery for the Jagdtiger. Low height (due to the huge recoil) and 36 Ah at 26 volts.
Gerhard
Christoffer Ahlfors
Has liked: 746 times
Been liked: 359 times
Post by Christoffer Ahlfors »
I have done it the Gerhard way, but I think the Sascha approach is still cool. It allows you to split the pack up and custom fit into your model. Finding enough space for the large monoliths is quite difficult.
On top of that, we have now seen a very safe way of encapsulating the terminals, so that nothing can get to them. First class! :D
Has liked: 161 times
Been liked: 830 times
Love the engine under the hood - fantastic details!
Christoffer Ahlfors
Sascha,
your build continues to impress.
Absolutely first class! Spitze! :D
yves mouton
Been liked: 741 times
Post by yves mouton »
Hello Sascha,
Awesome work on the recoil system for the jagdtiger 8)
Also nice looking details on the hull 8)
Best regards Yves
Chang
Has liked: 16559 times
Been liked: 487 times
Post by Chang »
Hi Sascha,
Like the 3D printed engine air filter details. Are these 4 handles printed too or metal parts added later on ?
Lerh Chang
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Post by Oliver Brüninghaus »
This is eye candy :!:
It's Grim Up North
Lovely work Sasha. The door mechanism looks great!
Chang
Post by Chang »
Stunning upgrade ! Are these replaced tube threaded ? Any reason not using stock's pins?
Paul Sparkes
Has liked: 97 times
Been liked: 243 times
Post by Paul Sparkes »
Sascha Hornbach wrote:
Sun Oct 24, 2021 7:46 pm
I must be completely mad :twisted: After a long building Weekend the new gun elevation is ready. A few parts could be recycled, but a lot are new. The elevation is now beside the mounting, to get space for the recoil stuff. All moving parts are a bit stronger now, to absorb the forces better. To lead the recoil mechanism I use a rail for 3D Printers or CNC machines. I also modified the Cylinder to get the exact length of 145mm recoil way later. Hope this works.... :oops: In pic 3 you can see the Compressor, the Airtank and the 2/3 way Valve.
regards
Sascha
I’d be really interested in more information on how you are making this work and what parts you have used.
Also I can see how to get 100mm recoil but 140 is very impressive.
I was going to use a servo with a linear slide but this setup with co2 interests me a lot.
222 scout car
Paul Sparkes
Has liked: 97 times
Sascha,
Very impressive work, I only hope my JT turns out half as good.
Do you know the thread size in the end of the barrel? I have modded mine for 140mm of recoil and just about to machine the other parts needed.
I don’t have the barrel here to measure and I want to design the mechanism.
Paul
222 scout car
Oliver Brüninghaus
Mmm yummy, your wheelhubs look brilliant.
What alloy did you use for the casting :?:
regards
Oliver
It's Grim Up North
Those end caps look really great! Excellent!
Chang
Post by Chang »
Hi Sascha,
How long is the leadscrew of the elevation mechanism? Customer-made or from Armortek?
Your modifications are really eyes wide open !
Lerh Chang
