Jagdtiger No.41 in Germany
- Has liked: 297 times
- Been liked: 645 times
- Gerhard Michel
- Has liked: 3 times
- Been liked: 687 times
Re: Jagdtiger No.41 in Germany
Hi Sascha,
why did you use 10 Ah cells to reach 30 Ah? 8 rectangular cells would be some easier to wire and would need less space, I mean.
This is my battery for the Jagdtiger. Low height (due to the huge recoil) and 36 Ah at 26 volts.
Gerhard
Gerhard
- Has liked: 746 times
- Been liked: 359 times
I have done it the Gerhard way, but I think the Sascha approach is still cool. It allows you to split the pack up and custom fit into your model. Finding enough space for the large monoliths is quite difficult.
On top of that, we have now seen a very safe way of encapsulating the terminals, so that nothing can get to them. First class!
- Has liked: 161 times
- Been liked: 830 times
Love the engine under the hood - fantastic details!
Sascha,
your build continues to impress.
Absolutely first class! Spitze!
- Been liked: 741 times
Hello Sascha,
Awesome work on the recoil system for the jagdtiger
Also nice looking details on the hull
Best regards Yves
Best regards Yves
- Chang
- Has liked: 16564 times
- Been liked: 487 times
Hi Sascha,
Like the 3D printed engine air filter details. Are these 4 handles printed too or metal parts added later on ?
Lerh Chang
Lerh Chang
- Has liked: 551 times
- Been liked: 409 times
- Chang
Stunning upgrade ! Are these replaced tube threaded ? Any reason not using stock's pins?
- Paul Sparkes
- Has liked: 97 times
- Been liked: 243 times
I’d be really interested in more information on how you are making this work and what parts you have used.Sascha Hornbach wrote: ↑Sun Oct 24, 2021 7:46 pmI must be completely madAfter a long building Weekend the new gun elevation is ready. A few parts could be recycled, but a lot are new. The elevation is now beside the mounting, to get space for the recoil stuff. All moving parts are a bit stronger now, to absorb the forces better. To lead the recoil mechanism I use a rail for 3D Printers or CNC machines. I also modified the Cylinder to get the exact length of 145mm recoil way later. Hope this works....
In pic 3 you can see the Compressor, the Airtank and the 2/3 way Valve.
regards
Sascha
Also I can see how to get 100mm recoil but 140 is very impressive.
I was going to use a servo with a linear slide but this setup with co2 interests me a lot.
222 scout car
222 scout car
- Paul Sparkes
Sascha,
Very impressive work, I only hope my JT turns out half as good.
Do you know the thread size in the end of the barrel? I have modded mine for 140mm of recoil and just about to machine the other parts needed.
I don’t have the barrel here to measure and I want to design the mechanism.
Paul
Paul
222 scout car
222 scout car
Mmm yummy, your wheelhubs look brilliant.
What alloy did you use for the casting
regards
Oliver
regards
Oliver
It's Grim Up North
- Chang
Hi Sascha,
How long is the leadscrew of the elevation mechanism? Customer-made or from Armortek?
Your modifications are really eyes wide open !
Regards,
Lerh Chang
Regards,
Lerh Chang
