Steves King Tiger
Re: Steves King Tiger
Hi Steve,
Blown away with this build, keep up the great work and super pics.
Best regards. Roy
Best regards. Roy
It could be worse, It could be Tuesday.
- Chang
- Has liked: 16515 times
- Been liked: 487 times
Re: Steves King Tiger's adjustable suspension
Quote:"Latest fully adjustable torsion bar suspension fitted, this is a initial production batch tank that has been upgraded to take the adjustable suspension."
Hi Steve,
This is very interesting upgrad. Can you explain more details about the works and how does it became "Adjustable"?
Have you enlarged more 18 holes on two suspension bars (CK0105)and inserted into 18 more shorten suspension shafts (half-cut-off CK0202 & CK0203, shown in circles)with shaft clamp screws?
If NO, please advise how did you do?
Thanks in advance and best regards.
Lerh Chang
Hi Steve,
Lerh Chang
- Has liked: 8 times
- Been liked: 701 times
Hi Chang
The suspension bars had to be machined by Mark of Armortek to accept the new torsion bar fittings, the bars also had to be shortened slightly.
- Been liked: 3680 times
Hi all
We are currently having a major re-organisation in the factory with a new mezzanine floor and upgrade of some of our CNC equipment. In the short term this is inevitably causing a lot of disruption. With the increasing number of model productions our stores area had become very overcrowded making it impossible to keep everything accessible and organised. The new mezzanine will give us a much larger area for the stores which will address this issue. However, as the saying goes 'it often has to get worse before it gets better' and at the moment accessing spares is very tricky.
Once the work is complete, apart from being able to supply individual spares in a more timely fashion, it is our intention to look at offering 'upgrade packs' where appropriate on older models. We will post all the details on the forum once available.
In the meantime we appreciate your patience while the work is competed.
Gill and Mark
Gill and Mark
- Been liked: 9 times
now that is great news
I still hate the wobbly wheels on my first gen tiger 1 an upgrade might be in the near future nice
colin
colin
2006 222 SOLD
2009 pzr111 046 SOLD
- Chang
Hi Steve,
(1) What are exactly these circled parts shown in your photo? Are new parts or simply the shortened suspension shafts (CK0202 & CK0203)? With 2 screw holes, they do look like them.
(2) What do your mean when you saying "the suspension bars also had to be shortened"? Why? I don't see your suspension bars (CK0105) had been shortened. Do you really mean the torsion bars (CK0204 & CK0205)?
Sorry to keep asking about your works. They do look better, and worth learning.
Lerh Chang
Lerh Chang
Hi Chang
The circled parts are new and not part of the origional suspension setup, these were ordered from Armortek.
I also shortened the torsion bars not the suspension bars as you noted.
- Chang
Hi Steve,
What is the name & code number of this part? Do you have the separated lined-drawing or photo of it? Thanks!
Lerh Chang
Lerh Chang
Hi Chang
I am sorry but I don't have the information you want, the build instructions went with the tank when it was sold, Mark at Armortek should be able to help you with all the required parts when the re-organisation is complete
- Chang
Hi Steve,
I have watched John Grima's film about Tiger 1's suspension upgrading:
Which looks similar with yours (from 5:35 to 7:05). I like this upgrading. But will only start mine later, after the Armortek finish their workshop's upgrading soon.
Also I found there are two smaller holes & bolts (in yellow circles) on the side hull:
Is this the new version? Or did you drill two smaller holes yourself and inserted bolts in?
Thanks in advance.
Lerh Chang
Thanks in advance.
Lerh Chang
Hi Chang.
The bolts you have circled are details that I have added, I do not know if this included in the later King Tiger issue.
- Chang
Hi Steve,
One more question (I promise):
What's the purpose to drill 2 small holes then insert bolts in beside each torsion bar hole? Are they there functionally or for decoration only? What function is it?
Lerh Chang
Lerh Chang
Hi Chang
These bolts are only a added detail and serve no purpose on the build.
