No. 37
- Brian Ostlind
- Has liked: 968 times
- Been liked: 2066 times
Re: Brian's Famo
Untitled by Brian Ostlind, on Flickr
Untitled by Brian Ostlind, on FlickrUntitled by Brian Ostlind, on FlickrUntitled by Brian Ostlind, on Flickr
- Has liked: 292 times
- Been liked: 639 times
Re: Brian's Famo
Good luck Brian with theese lots of parts.
Something about 3.800, if I remember right
BUT you will need some more rivets + the motion option parts...
- Brian Ostlind
- Has liked: 2259 times
- Been liked: 7147 times
Re: Brian's Famo
Hi Brian, do you have the motors, you will need to install them now as you go or you will have difficulty later?
- Has liked: 218 times
- Been liked: 178 times
Re: Brian's Famo
Hi Brian
Looking good as Phil said get the motors in now otherwise its a major strip down to fit them later.
Also check the torsion bar ends fit in the brass bearing blocks some of mine didn't and I had to ream them out
which ment seperating the two sides to get access to the one with the countersunk hole.
Hope this helps
Hope this helps
Re: Brian's Famo
Hi Brian,
that's true. Motors and gearboxes should now be installed. The screws for the countershaft must be inserted before the motors are tightened. You have no place to use it later because the motor mount is in the way.
I deburred the brass parts and, if necessary, inserted the corrosion springs with a long screw. - later tightened with the shorter one.
- Brian Ostlind
Re: Brian's Famo
I ordered motion but won’t receive it for a while. Might use the King Tiger motors i have if they are interchangeable.
- Brian Ostlind
Re: Brian's Famo
I made sure they fit before joining the two halves.
Derek Attree wrote: ↑Thu Nov 26, 2020 10:59 amHi Brian
Hope this helps
- Brian Ostlind
Re: Brian's Famo
I have kt motors I hope I can use.Phil Woollard wrote: ↑Thu Nov 26, 2020 9:19 amHi Brian, do you have the motors, you will need to install them now as you go or you will have difficulty later?
Re: Brian's Famo
I've no idea if the KT motors will fit mate best ask the management!
- Brian Ostlind
- Brian Ostlind
Re: Brian's Famo
I found out bad news that my KT motors won't fit will have to wait for the Famo motors to arrive.
- Tom Miller
- Been liked: 325 times
Re: Brian's Famo
Brian,
I was able to install my motors after the frames were joined. There are instructions in the option pack manual on how to do this. It is not easy but it can be done. If you can do it before joining the frames do it. If you do not want to wait just know it can be done.
Tom
Tom
- Brian Ostlind
Re: Brian's Famo
Good to know. I am not sure what you mean by frames...Tom Miller wrote: ↑Fri Nov 27, 2020 5:02 pmBrian,
Tom
- Tom Miller
Re: Brian's Famo
Armortek calls them chassis rails.
I do not recommend installing the motors later. It does require removing some parts and getting to some of the bolts was to say the least difficult. I only offered this info incase your motors are several months out. Better to move on to other assemblies and install the motors before proceeding with the chassis.
If you check out my blog when I built my FAMO you will see I did a lot of remachining and modifying of some parts. This kit is rather challenging to assemble and if you do not have a lathe and mill it is not easy to modify some of the parts. We live only about an hour apart. If you require any machine work I am here to help.
Good Luck,
Tom
Good Luck,
Tom
