Derek Attree wrote: ↑Thu Nov 26, 2020 10:59 amHi Brian
Looking good as Phil said get the motors in now otherwise its a major strip down to fit them later.
Also check the torsion bar ends fit in the brass bearing blocks some of mine didn't and I had to ream them out
which ment seperating the two sides to get access to the one with the countersunk hole.
Hope this helps
I have kt motors I hope I can use.Phil Woollard wrote: ↑Thu Nov 26, 2020 9:19 amHi Brian, do you have the motors, you will need to install them now as you go or you will have difficulty later?![]()
Good to know. I am not sure what you mean by frames...Tom Miller wrote: ↑Fri Nov 27, 2020 5:02 pmBrian,
I was able to install my motors after the frames were joined. There are instructions in the option pack manual on how to do this. It is not easy but it can be done. If you can do it before joining the frames do it. If you do not want to wait just know it can be done.
Tom
