Anyone use a tamiya dmd unit in their tank?
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Michael,
I've put the link to Thomas's site below. I suggest you e-mail him and tell him what you want the amplifier for and tell him that the input will be the output from the Tamiya sound system. He will then supply you with the correct amplifier. All you then do is connect the Tamiya speaker wire to the amplifier input. The amplifier then has two output wires to connect to the speakers. If you want two speakers then connect them in parallel, but use 8 ohm speakers.
http://www.benedini.de
Allan Richards
Robert Bruce
Post by Robert Bruce »
Or you could go to Maplins and buy one of the many amps they have to do the job I use the the little 7amp kit for £7.95 which does the job :wink:
All Tanked up
Robert
UKTC " Battle Group Nord"
David Pengelly
Been liked: 2 times
Post by David Pengelly »
There are several tank owners that have fitted the tamiya sound system in thier tanks , the following link shows the wiring diagram ( scroll to the bottom of the page )
http://uktankclub.star-one.co.uk/phpbb2 ... php?t=2332
The only drawback as i can see is that it only provides for one stick for forward and reverse, and the other stick for steering. Personally i like twinstick control.
Was die Hölle das war
Allan Richards
Dave,
You can still set the tank up to drive with two sticks set as fwd and rev as the Tamiya DMD is not used to work the motors, just provide the sound.
Allan Richards
David Skeldon
Has liked: 33 times
Been liked: 312 times
Post by David Skeldon »
Hi Robert.
Do you have a part number for the Maplins amp you used.
David Pengelly
Been liked: 2 times
The Maplins amplifier part No is :- VM114. Its a 7W audio amplifier module
It comes prepacked, probably find it opposite the model helicopters :P
David Skeldon
Has liked: 33 times
Hi,
Thanks for that,What speaker do you think is best.
David.
