Anyone use a tamiya dmd unit in their tank?
- Been liked: 4 times
If so could you explain or show me a diagram for wiring..I really dont want to blow up one of this dmd units since they cost so much..thanks and happy new year
didonatom2279@bellsouth.net
- Been liked: 1 time
Check your E-Mail, I sent a 268 k jpg diagram (Tamiya Sound kit on Armortek TI wiring.jpg). It is by I. Taylor and P. Morris dated September 2004 showing Turret Rotation, Barrel Elevation, Speed Controls. Since it is not my drawing, and since I do not know them, I was hesitant to post it here but it may be somewhere on the older Armortek Forum.
You might double check this info to insure nothing has changed over recent years.
- Has liked: 31 times
- Been liked: 304 times
- Been liked: 10 times
Michael,
The DMD is powered from the 7.2v battery packs as described in the Tamiya instructions. There is a plug on the DMD that will fit the standard plug on the 7.2v battery The DMD then also powers the receiver from this battery. If you are thinking of going this route get yourself a copy of the Tamiya instructions as you will then see how to connect up the the DMD and do the initial setup functions - its not difficult.
Allan Richards
Allan& David, Do you use the stock single speaker for sound or did you modify the sound system in anyway? I was thinking about adding another speaker, or even maybe using an amplified speaker. Im not too sure if the sound is going to be loud enough. I still having tried it yet as im still wiring up everything. Thanks guys..
Allan,Allan Richards wrote:Michael,
There is a volume screw on the MF unit I think that can be adjusted. I have fitted a Benedini amp and two larger speakers as the sound is attenuated quite a bit by the large metal box of a hull.
Is there any way you could explain in better detail of what you did?
I think this is what im looking to do, but not know where to get the benedini amp or which one and wiring details. If you can help thanks..
