ARMORTEK’S NEWEST KITS ARE HERE
- Has liked: 240 times
- Been liked: 217 times
Re: ARMORTEK’S NEWEST KITS ARE HERE
Another question, could a canvas top for the halftrack be an option on this run?
Quicquid agas age
- Has liked: 70 times
- Been liked: 307 times
Another question
Is there any plan to provide the armour shield for the Flak 88?
- Has liked: 1480 times
- Been liked: 1685 times
The original kit came with the armour so I can't see any reason this run would omit it.
- Has liked: 2526 times
- Been liked: 96 times
- Been liked: 1839 times
Alex
There was a Canopy for the original K7 supplied by Armortek way back when. It was specially ordered and you had to wait months for it.
" These things cannot be rushed" I was told. I envisaged a little old lady busily sewing away in a little cottage deep in the west country.
Fit was questionable and it comprised of metal rods bent (Thick welding rod) to form a frame connected to two brackets bolted to the side of the hull. You had to drill the front screen frame and had to make up your own fasteners to hold it in place.
A piece of paper came with it, which basically said fit frame and tie canopy to said frame using valcro tags supplied. dye or paint as required.
Now I knew I wasn't going to be getting the wonderful framed unit you'll see on Simon Mannings K7, but I had paid a fair bit for this canopy.
But it was what it was, so making the best of it cut 20mm off the bottom edge and fitted a stainless steel wire in the hem which I had stitched back in, now it would hold it's shape.
When the Famo's came out with a canopy included and saw it, I thought you lucky so and so's, really nice and it came with a rear view curtained window too........
If the Simon Manning's canopy becomes available again, get it! I think there was a drawing too, but you had to be talented with a sewing machine.
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1113 times
I have that Armortek frame and canopy but opted to use the beautiful canopy and frame made by Mr Matata.
The photo does not do it justice:
Hummm, yes.
That's the one I wanted Jerry, lot's of K7 aftermarket bit's pieces were available, but some fell into the "unobtanium" category.
You could spend a small fortune on detail stuff. There were working trafficators, dash details.
I'm guessing it'll be a lot better detailed this time around, that's the beauty of the re editions.
The very first models came with solid cast head lamp housings. If I remember correctly, you sent your originals off and in return you got hollowed out housings for all including side lamp with some lens.
Someone made the flexi hitch to ease the twist on towing, so I had ago at one of those too.
Somebody, can't think who, had a complete new window frame made with working louver vent. lovely piece of work it was.
The proper head light glazing sets were rare too and all those fitments for the rifles will keep you busy for hours.
Dave Dibbs could have field day with this lot.
Great model loads of scope.
Mind you, stay away from certain number plates, you might not be welcome at some shows.
- Chris Hall
- Has liked: 533 times
- Been liked: 686 times
I think it’s Andreas Wolfrom in Germany …..John Clarke wrote: ↑Sat May 18, 2024 12:24 pmSomebody, can't think who, had a complete new window frame made with working louver vent. lovely piece of work it was.
- Jerry Carducci
My my added details are a combination of parts from Michael Matata, Tim Catton and parts of my own making. I made my dash illuminated, and all the exterior lights functional. I made the decision not to cover all the fasteners on this model as I've learned that should the need arise to do repairs of changes having to dig out the screws can cause more disruption than I want. With the body panels as thin as they are, and necessarily so, it's dangerous to attempt to countersink the screw heads beyond a point; one literally needs to extend the countersink into the base surface to allow the screw head clearance; that or try to locate flat head screws with and undercut to the head...
I really like the Sd Kfz 7 and look forward to a second kit, perhaps this time I'll get the building a little better.
