- Has liked: 2267 times
- Been liked: 7152 times
Printing underway!
- Has liked: 777 times
- Been liked: 1744 times
Found a photo of the exhaust expansion box you mentioned a couple of days ago and made a quick draft of it. Obviously all dimensions are not correct.
- Has liked: 1024 times
- Been liked: 2094 times
You asked and I've found this in my files:
Trust it will help you. Stephen
You have been busy vince! We could do with ivano's dimension of the main engine exhausts centres , I will take some measurements and we could do draft to see if it will work?
Just seen your post Stephen and thank you once again, I will have a look tomorrow and digest the figures.
Thanks for that Stephen. Having a top view and side view really helps.Trust it will help you. Stephen
Phil that silencer looks good.
There's lots of interesting angles going on with both the exhaust systems, the auxiliary engine has a very long run, I shall enjoy replicating that lot very much!
Ivano we need to know the centres of these pipes taken from the L60 engine you are making for us?
- Expansion Box v1_kindlephoto-82342.jpg (30.01 KiB) Viewed 521 times
- Ivano I need the measurement of the centres of these pipes taken from the engine that you are building?
- FV742727-003_kindlephoto-4940395.jpg (12.13 KiB) Viewed 522 times
- FV742727-003_kindlephoto-4862662.jpg (18.73 KiB) Viewed 522 times
- FV742727-003_kindlephoto-4905061.jpg (29.36 KiB) Viewed 522 times
Engine/gearbox bay geu exhaust work. I do enjoy fabricating these.
What's the diameter of those two copper pipes? 1/2" or 3/4"?
15 mm vince.
I wasn't too far off. I modelled mine as 16mm.
Also be advised that although my drawing shows pipes with bellows, they are not functional. They are not flexible. Also I can't draw bends in bellows.
That's fine Vince I can sort the bends out.
- This gearbox model shows the brackets for the smoke box.
- A1741.jpg (98.63 KiB) Viewed 478 times
- The gearbox was a beautiful thing for sure, shame it wasn't much good.
- Im201304Tank-i078.jpg (101.12 KiB) Viewed 478 times
- Been liked: 735 times
Hi Phil,
i have not reproduced the exhausts,
there was no space. I can give you this size, the tubes are on the sides of the head. The brackets measure 14.5 mm. they are not sure they are correct, maybe you will have to do it again. Without the tank it is difficult to guess. Tell me if the information is useful.
Thanks!
Thanks!
Thanks Ivano that's great.
Now I have the false floor over the electric motors I can give you the exact distance between the "T piece" and the floor if you like?
Thanks but I don't think I need it, the boxes of the sefrigerante are already in print. Also for the other pieces the OK was given for the realization. We cross our fingers and hope well!
