Has liked: 2267 times
Been liked: 7152 times
Printing underway! 8)
Has liked: 777 times
Been liked: 1744 times
Found a photo of the exhaust expansion box you mentioned a couple of days ago and made a quick draft of it. Obviously all dimensions are not correct.
Has liked: 1024 times
Been liked: 2094 times
You asked and I've found this in my files:
Trust it will help you. Stephen
You have been busy vince! We could do with ivano's dimension of the main engine exhausts centres , I will take some measurements and we could do draft to see if it will work? 8)
Just seen your post Stephen and thank you once again, I will have a look tomorrow and digest the figures. 8)
Looking good.
Looking good.
Thanks for that Stephen. Having a top view and side view really helps.
Phil that silencer looks good.
There's lots of interesting angles going on with both the exhaust systems, the auxiliary engine has a very long run, I shall enjoy replicating that lot very much!
Ivano we need to know the centres of these pipes taken from the L60 engine you are making for us?
Expansion Box v1_kindlephoto-82342.jpg (30.01 KiB) Viewed 525 times
Ivano I need the measurement of the centres of these pipes taken from the engine that you are building?
Engine/gearbox bay geu exhaust work. I do enjoy fabricating these. 8)
Vince we can get a good idea of the exhaust pipe dimensions  from these two photos.
What's the diameter of those two copper pipes? 1/2" or 3/4"?
15 mm vince.
I wasn't too far off. I modelled mine as 16mm.
Also be advised that although my drawing shows pipes with bellows, they are not functional. They are not flexible. Also I can't draw bends in bellows.
That's fine Vince I can sort the bends out. 8)
This gearbox model shows the brackets for the smoke box.
The gearbox was a beautiful thing for sure, shame it wasn't much good.
Ivano Costantini
Been liked: 735 times
Post by Ivano Costantini »
Hi Phil,
i have not reproduced the exhausts,
there was no space. I can give you this size, the tubes are on the sides of the head. The brackets measure 14.5 mm. they are not sure they are correct, maybe you will have to do it again. Without the tank it is difficult to guess. Tell me if the information is useful.
Thanks!
Ivano Costantini
Sorry, here are the photos
Thanks Ivano that's great.
Now I have the false floor over the electric motors I can give you the exact distance between the "T piece" and the floor if you like? 8)
Ivano Costantini
Thanks but I don't think I need it, the boxes of the sefrigerante are already in print. Also for the other pieces the OK was given for the realization. We cross our fingers and hope well!
