Panther G 2022 #15 Build
Malcolm.Plumb
Has liked: 454 times
Been liked: 920 times
Re: Panther G 2022 #15 Build
Post by Malcolm.Plumb »
Straight forward and all now ready to be masked off, primed further and painted tomorrow.
All dependent on the weather here obviously :|
2022 Panther G #15
Malcolm.Plumb
Some reasonable weather this morning so managed to get the drive sprockets finished. :D
I 'm going to wait a few days for the paint to harden before handling so have now moved on to checking out the tracks.
Only looks like some have a small amount of flashing to remove so that's a good thing. :wink:
A tedious task but I think I'm going to etch prime and paint the links individually before assembly.
I'm thinking grey primer and then matt black or dark grey for starters.
Not quite sure at the moment. :?
What would be the correct colour?
2022 Panther G #15
mark lawson
Has liked: 2519 times
Been liked: 444 times
Post by mark lawson »
Just hit them with either black or a dirty brown colour. With weare the primer will show.
Dirty brown as that's what happens to tank tracks with use.
RAG Militärmodellbau
IG Militärmodellbau
Malcolm.Plumb
Thanks Mark
OK, so need to be looking for some spray cans of a suitable brown then.
Unless I still go with black and dirty it up later.
I do have a spray gun and airbrushes but be easier in cans I think.
Will have a look to see what browns are about
2022 Panther G #15
Malcolm.Plumb
A bit cold out there today but managed to get a few track links primed.
Deburring links sat up in my model building room and then cleaning and priming outside in small batches for now.
These done today are going to be brown base coated next to see what they look like and am going to try the AK Tracks primer out.
A long job this way I think but no rush..
2022 Panther G #15
Malcolm.Plumb
Just a few track links painted to see how they look.
2022 Panther G #15
Malcolm.Plumb
Some time and reasonable weather and the long and tedious task of individually priming and painting the track links continues.
Still a long way to go I think :|
2022 Panther G #15
Malcolm.Plumb
Finally after hold ups to do with the poor weather and then weeks and weeks of painting track links I have tonight started track assembly. :D
Managed to get hold of some black M3 washers and some shorter split pins as well to avoid having to cut any surplus length off.
2022 Panther G #15
Malcolm.Plumb
A couple of hours on the build this afternoon.
Left side track in two parts now given its dusty coat.
No heavy deposits to be added due to the dry summer weather.
2022 Panther G #15
Gary Rafferty
Has liked: 252 times
Been liked: 442 times
Post by Gary Rafferty »
Hi Malcolm
Tracks looking really good nice to see you are moving forwards with your build
Gary
Malcolm.Plumb
Thanks Gary
Such a long time to do but my fault mainly. :|
Be nice to get the drive sprockets fully on and get the tracks out of the way.
So much more interesting and less tedious things to do with the build :)
2022 Panther G #15
Damon Resch
Has liked: 907 times
Been liked: 82 times
Post by Damon Resch »
Malcom, what brand and model of spray gun are you using?
Malcolm.Plumb
Hi Damon
This one is a MR Hobby PS290.
0.5mm needle which has an additional fan nozzle included.
I also have the optional larger paint cup and extension handle.
Works well for the slightly bigger stuff with out going to a full size spray gun.
https://www.mr-hobby.com/en/product3/category_2/19.html
2022 Panther G #15
Malcolm.Plumb
Drive sprockets on and track test fit.
84 links :)
Needs a couple of permanent track pins and securing fully.
2022 Panther G #15
Malcolm.Plumb
Both tracks now fully fitted along with the rear idler hub caps.
A long time spent with this but that's the running gear done for now apart from fitting the road wheel hub caps and securing the drive gear hub cap plus fittings.
Next up, back on to the decks of the tank last visited many months ago.
2022 Panther G #15
