JT CO2 Recoil how I did it
Paul Sparkes
Has liked: 97 times
Been liked: 243 times
Post by Paul Sparkes »
I get a lot of requests for information on how I did the CO2 recoil on my Jagdtiger so instead of repeating myself on PM I have decided to post it up.
This is how I achieved my recoil, others have done similar. I hope this helps others.
I am currently working on another forum members JT recoil so an ideal opportunity to explain a few things clearly.
It uses simple pneumatics to retract the gun barrel and then release it slowly, The gun had been modified to have 85mm of recoil I use 80mm of this and then install a bump stop internally to save the bang at full extension. The JT can be modified up to 140mm of travel but this is too much for my battery location, so I am happy with 80mm and it works well without major modifications to the gun assembly.
So a CO2 canister is connected to a CO2 regulator and set to approx 45psi (Blue hose) this pressure is then sent in 2 directions 1st is the 5 way pneumatic solenoid valve and the other is into a second regulator which lowers the pressure further to around 15psi for the Gun smoke Vape. (Orange hose)
On energising the 5 way pneumatic solenoid valve (12v trigger) the co2 pressurises the cylinder on the gun and the barrel retracts, When the solenoid is not energised (power removed) the gun barrel returns to its out position but is slowed by the adjustable valve on the return side of the cylinder.
On top of all this I changed the elevation and slew to linear actuators for precise reliable movement the elevation is using a 50mm and the slew a 30mm pictures in my thread for those interested.
Triggering this is done on my JT using the Beier USM RC3 sound system which is easily programmed for such things. It should be achievable using the AT recoil module by using a relay system of just get one of my Gun smoke kits. (Not tested, but it should be workable)
All of the above principles can be applied to most recoil systems but has been aimed at the larger heavier guns.
The videos are from before I did my heavy duty linear servos but show the gun recoil
More videos on my channel http://www.youtube.com/@TheMinimivic
Happy New year to all.
222 scout car
Tim Carr
Has liked: 2532 times
Been liked: 96 times
Re: JT CO2 Recoil how I did it
Post by Tim Carr »
Wow, What a Bang to bring in the New Year!
Looks nice and Thanks for sharing.
Later Tim
My Tiger #131 Build thread
viewtopic.php?t=9876
Tampa Bay, Fla area USA.
Gerhard Michel
Has liked: 3 times
Been liked: 687 times
Post by Gerhard Michel »
Well done, indeed! Only the recoil length might be some langer. The Jagdtiger had a maximum recoil length of 90 cm (hot gun); because there was no muzzle brake. This would be up to 15 cm in 1/6 scale.
Gerhard
Paul Sparkes
Has liked: 97 times
Gerhard Michel wrote:
Mon Jan 01, 2024 10:27 pm
Gerard, yes close to 14cm is achievable with major alterations to the gun. I would need to change the interior layout to accommodate this and I don’t intend to at this time. My workings will allow others to get scale recoil if they so wish.
222 scout car
Gerhard Michel
Has liked: 3 times
Hi Paul,
well, I'm some kind of 'recoil fetichist'. With my Bigtanks Jagdtiger I achieved the full recoil length by using a servo with a prolonged servo lever and a push rod. This was possible because my gun barrel is much lighter than Armortek's barrel. With a servo the moving speed can also be altered while moving; not only faster moving backwards and slower moving forward, but starting fast and reduce the speed underway. Well, I'm aware that this is somehow overstated.... :twisted:
Gerhard
Robert Reid
Has liked: 99 times
Been liked: 446 times
Post by Robert Reid »
That is amazing!
Well done!
RPR
yves mouton
Been liked: 741 times
Post by yves mouton »
WOW Paul,
Amazing job on the recoil 8) 8) 8)
Best regards Yves
